Hi there,
I have connected gyro with arduino using I2C protocol (SCL/SDA) and I have connected a BLDC The motor driver is this one: https://flipsky.net/products/mini-fsesc4-20-50a-base-on-vesc-widely-used-in-eskateboard-escooter-ebike
But when I try to rotate the motor based on angle data the serial monitor freezes. Gyro data stopped giving output. If I disconnect the motor driver wires then the data is showing perfectly.
I have also tried to control the motor without gyro, it works fine. But I can't understand why I can't rotate motor and read gyro data together.
Any suggestion??
