UART Ultrasonic Sensor A0221AU Not working properly
I am using a A0221AU UART Ultrasonic Sensor and it is not responding as expected.
It gives a few readings at first and then sometimes does not respond.
I am using the DFRobot Example code. I already check and make the connection permanent but it still does not respond sometimes.
Please tell me is that a problem in the code or the sensor itself.
Thanks in advance.
Heres the code and the source link
#include<SoftwareSerial.h>
int pinRX1 = 11;
int pinTX1 = 10;
int pinRX2 = 13;
int pinTX2 = 12;
unsigned char data_buffer1[4] = {0};
unsigned char data_buffer2[4] = {0};
unsigned char data_buffer3[4] = {0};
unsigned char data_buffer4[4] = {0};
int distance1 = 0;
int distance2 = 0;
int distance3 = 0;
int distance4 = 0;
unsigned char CS1;
unsigned char CS2;
unsigned char CS3;
unsigned char CS4;
SoftwareSerial mySerial (pinRX1, pinTX1);
  Serial1.begin(9600);
  Serial2.begin(9600);
  Serial3.begin(9600);
  mySerial.begin(9600);
  if (mySerial.available()>0){ //sensor 1
    delay(4);
    if (mySerial.read() == 0xff){
      data_buffer1[0] = 0xff;
      for(int i = 1; i<4; i++){
        data_buffer1[i] = mySerial.read();
      CS1 = data_buffer1[0] + data_buffer1[1] + data_buffer1[2];
      if (data_buffer1[3] == CS1){
        distance1 = (data_buffer1[1] <<8) + data_buffer1[2];
        delay(5);
        Serial.print("distance 1: ");
        Serial.print(distance1);
        Serial.println(" mm ");
  else if (Serial1.available()>0){ //sensor 2
    delay(4);
    if (Serial1.read() == 0xff){
      data_buffer2[0] = 0xff;
      for(int j = 1; j<4; j++){
        data_buffer2[j] = Serial1.read();
      CS2 = data_buffer2[0] + data_buffer2[1] + data_buffer2[2];
      if (data_buffer2[3] == CS2){
        distance2 = (data_buffer2[1] <<8) + data_buffer2[2];
        delay(5);
        Serial.print("distance 2: ");
        Serial.print(distance2);
  else if (Serial2.available()>0){  //sensor 3
    delay(4);
    if (Serial2.read() == 0xff){
      data_buffer3[0] = 0xff;
      for(int k = 1; k<4; k++){
        data_buffer3[k] = Serial2.read();
      CS3 = data_buffer3[0] + data_buffer3[1] + data_buffer3[2];
      if (data_buffer3[3] == CS3){
        distance3 = (data_buffer3[1] <<8) + data_buffer3[2];
        delay(5);
        Serial.print("distance 3: ");
        Serial.print(distance3);
  else if (Serial3.available()>0){ //sensor 4
    delay(4);
    if (Serial3.read() == 0xff){
      data_buffer4[0] = 0xff;
      for(int l = 1; l<4; l++){
        data_buffer4[l] = Serial3.read();
      CS4 = data_buffer4[0] + data_buffer4[1] + data_buffer4[2];
      if (data_buffer4[3] == CS4){
        distance4 = (data_buffer4[1] <<8) + data_buffer4[2];
        delay(5);
        Serial.print("distance 4: ");
        Serial.print(distance4);
        Serial.println(" mm");
        Serial.println(" ");
Really? The code in your post doesn't look anything like the code in the Dfrobot wiki you linked to.
What happens if you:
  • try the code in the wiki?
or
  • modify the code you posted so it is attempting to read only one sensor, the "mySerial" one (not the Serial1, 2, and 3 ones...)?
i modify the code from the wiki cause when "i use 4 device i cant use only software serial" someone told me on the arduino discord forum... and i dont really get it with the 2nd point (sorry i dont really understand english)
My suggestion: first, get one sensor working. Try the wiki code. Add more sensors later.
Which Arduino board (or "compatible") are you using?
sorry for late answer im using MEGA2560
@DaveEvans i already testing it but when it comse to the 4th sensor, the sensor often sense low range and sense a bit late
