UART Wifi V2
Hello everyone,
I'm totally new to arduino and I have some troubles in setting up that grove module, I always get this error saying "warning: espcomm_sync failed".
Can somebody please help me ?
Thanks !
what do you want to upload to the module and how did you wire it?
I’m wiring it with the grove base shield and I just want to connect my arduino to my Wifi connection using this code :
#include <ESP8266WiFi.h> // Include the Wi-Fi library
const char* ssid = “SSID”; // The SSID (name) of the Wi-Fi network you want to connect to
const char* password = “PASSWORD”; // The password of the Wi-Fi network
Serial.begin(115200); // Start the Serial communication to send messages to the computer
delay(10);
Serial.println(’\n’);
WiFi.begin(ssid, password); // Connect to the network
Serial.print(“Connecting to “);
Serial.print(ssid); Serial.println(” …”);
int i = 0;
while (WiFi.status() != WL_CONNECTED) { // Wait for the Wi-Fi to connect
Serial.print(++i); Serial.print(’ ');
Serial.println(“Connection established!”);
Serial.print(“IP address:\t”);
Serial.println(WiFi.localIP()); // Send the IP address of the ESP8266 to the computer
void loop() { }
the module has AT firmware. write a sketch for Uno with WiFiEsp library.
don't use the esp8266 arduino package unless you know what you are doing
Thanks !
Do you have any link to install this library please ?
Tyzerath:
Thanks !
IDE, Sketch menu, Include Library option, Manage Libraries option
Thanks !
But now I get this error saying while uploading the exemple sketch for wifi:"avrdude: stk500_getsync()", do you have any solution ?
Tyzerath:
Thanks !
don't connect the module to RX/TX. it disturbs the Serial upload over USB (usb is tha same Serial as RX/TX pins). use connector 6 on base shield. the examples of the WiFiEsp library create software serial instance on pins 6 and 7
It's now working, you're amazing thank you ! But now I have an other issue, sorry i'm terribly bad, it's saying :
10:36:26.603 -> [WiFiEsp] I >>> TIMEOUT >>>
10:36:26.603 -> [WiFiEsp] Cannot initialize ESP module
10:36:26.603 -> [WiFiEsp] Initializing ESP module
10:36:27.600 -> [WiFiEsp] >>> TIMEOUT >>>
10:36:29.636 -> [WiFiEsp] >>> TIMEOUT >>>
10:36:31.643 -> [WiFiEsp] >>> TIMEOUT >>>
10:36:33.636 -> [WiFiEsp] >>> TIMEOUT >>>
10:36:35.633 -> [WiFiEsp] >>> TIMEOUT >>>
10:36:36.657 -> [WiFiEsp] Cannot initialize ESP module
Tyzerath:
now the module doesn't answer
upload this sketch:
#include "SoftwareSerial.h"
SoftwareSerial Serial1(6, 7); // RX, TX
  Serial1.begin(115200);
  if (Serial.available()) {      // If anything comes in Serial (USB),
    Serial1.write(Serial.read());   // read it and send it out Serial1 (pins 0 & 1)
  if (Serial1.available()) {     // If anything comes in Serial1 (pins 0 & 1)
    Serial.write(Serial1.read());   // read it and send it out Serial (USB)
then open Serial Monitor, set 115200 baud and line ends "both".
try to send AT. you should get OK as response. if yes, then send
AT+UART_DEF=9600,8,1,0,0
to change the default baud rate
then try the WiFiEsp example again
The outputs are going too fast I can't see if there is an "ok" or not.
Nevermind, I followed you instructions and it’s now working, you can’t imagine how thankful I am
You did a great job, thanks !
the WiFiEsp library has some problems. the main problem is that it can't receive large data. so if you have trouble with this, write here. there are then other options: other firmware or your own sketch for the WiFi module
Thanks ! But don't worry it's a small project, have a nice day !
