Hallo,
ich wollte mir nach Folgender Anleitung einen GPS Tracker bauen. Allerdings habe ich nur eine Ublox NEO 6M zur Verfügung. Was muss ich im Code verändern damit das funktioniert?
#include <AltSoftSerial.h>
#include <SdFat.h>
#include <avr/pgmspace.h>
// *** glocal objects ***************************************************
// TODO: Parameter auf SD-Karte speichern
const int GPS_RATE = 1; // 1, 5, 10
const int DEBUG_RAM = 0; // 1, 0
// *** functions *********************************************************
int freeRam() {
extern int __heap_start,*__brkval;
int v;
return (int)&v - (__brkval == 0 ? (int)&__heap_start : (int) __brkval);
void print_free_ram() {
if (DEBUG_RAM == 1) {
Serial.print(F("LocLog: "));
Serial.print(F("Free SRAM = "));
Serial.println(freeRam());
void useInterrupt(boolean v) {
if (v) {
// Timer0 is already used for millis() - we'll just interrupt somewhere
// in the middle and call the "Compare A" function above
OCR0A = 0xAF;
TIMSK0 |= _BV(OCIE0A);
else {
// do not call the interrupt function COMPA anymore
TIMSK0 &= ~_BV(OCIE0A);
inline void sd_get_new_logfile(SdFat &sd, char *logfile_name) {
SdFile f;
uint8_t lognr = 0;
while (lognr == 0 || sd.exists(logfile_name)) {
lognr++;
sprintf(logfile_name, "log%05i.nmea", lognr);
Serial.print(F("Open file "));
Serial.print(logfile_name);
Serial.println(F(" for logging."));
inline void gps_setup(AltSoftSerial &gpSerial) {
// connect to gps
gpSerial.begin(9600);
delay(100);
// set up baud rate 38400
gpSerial.println(F("$PMTK251,38400*27"));
delay(100);
gpSerial.end();
// re-connect
gpSerial.begin(38400);
// configure update rate
if (GPS_RATE == 1)
gpSerial.println(F("$PMTK220,1000*1F")); // 1hz
if (GPS_RATE == 5)
gpSerial.println(F("$PMTK220,200*2C")); // 5hz
else if (GPS_RATE == 10)
gpSerial.println(F("$PMTK220,100*2F")); // 10hz
// configure NMEA sentences frequency
// - No GLL, 10Hz RMC, No VTG, 2Hz GGA, GSA, GSV
delay(100);
gpSerial.println(F("$PMTK314,0,1,0,5,5,5,0,0,0,0,0,0,0,0,0,0,0,0,0*2C"));
delay(100);
// enable SBAS
gpSerial.println(F("$PMTK313,1*2E"));
delay(100);
// allow SBAS testing signals
gpSerial.println(F("$PMTK319,0*25"));
delay(100);
// search for SBAS sats
gpSerial.println(F("$PMTK513,1*28"));
delay(100);
// no antenna status
gpSerial.println(F("$PGCMD,33,0*6D"));
inline void command_directory_listing(SdFat *sd) {
sd->ls(LS_SIZE);
Serial.print(F("LocLog: Listing completed."));
inline void command_retrieve_log(SdFat *sd, const char* file) {
Serial.print(F("LocLog: Retrieving file "));
Serial.println(file);
if (sd->exists(file)) {
SdFile logfile;
if (logfile.open(file, O_READ)) {
char buf;
while ((buf = logfile.read()) >= 0)
Serial.write(buf);
Serial.print(F("LocLog: End of log."));
logfile.close();
Serial.print(F("LocLog: Could not open file."));
Serial.print(F("LocLog: File not found."));
// *** glocal objects (used only in setup and loop) *********************
AltSoftSerial gpSerial;
SdFat sd;
SdFile file;
ofstream sdout;
char logfile_name[13];
bool hasSDCard = false;
bool isLogging = false; //TODO only log when fix available
// TODO: name log file to fix date
// TODO: log time to first fix
uint32_t timer = millis();
uint32_t distance = 0;
float lastLat=0, lastLon=0;
char c;
char checksum_char;
uint8_t checksum_step = 0;
String checksum_string;
String checksum_reference;
String nmea_sentence;
String command;
uint16_t sentences_all = 0;
uint16_t sentences_valid = 0;
uint16_t sentences_invalid = 0;
uint32_t bytes_read = 0, bytes_written = 0;
uint8_t menu_page = 0;
// *** setup *************************************************************
Serial.begin(57600*2);
Serial.println(F("LocLog v. 1.1 starting..."));
// enable GPS chip
pinMode(2, OUTPUT);
digitalWrite(2, HIGH);
// initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
// breadboards. use SPI_FULL_SPEED for better performance.
if (sd.begin(10, SPI_FULL_SPEED)) {
hasSDCard = true;
//sd.initErrorHalt();
Serial.println(F("No SD CARD. Logging disabled!"));
hasSDCard = false;
pinMode(10, OUTPUT);
gps_setup(gpSerial);
print_free_ram();
Serial.println(F("Startup completed."));
// finished
// *** loop *************************************************************
void loop() // run over and over
// read and process data from gps
if (gpSerial.available()) {
c = gpSerial.read();
bytes_read++;
if (c != '\r')
nmea_sentence += c;
switch (c) {
case '
Danke für die Hilfe!
Grüße
Kai:
checksum_step = 1;
case '*':
checksum_step = 3;
checksum_string = "";
case '\r':
case '\n':
checksum_step = 4;
checksum_reference = String(checksum_char, HEX);
if (checksum_reference.length() == 1)
checksum_reference = "0" + checksum_reference;
if (checksum_string.equalsIgnoreCase(checksum_reference) == true) {
sentences_valid++;
else {
sentences_invalid++;
sentences_all++;
// write this sentence to bluetooth and sd card
Serial.print(nmea_sentence);
if (!nmea_sentence.startsWith("$GPGSV") && hasSDCard) {
if (!isLogging) {
int date_stop = nmea_sentence.lastIndexOf(',', nmea_sentence.lastIndexOf(',', nmea_sentence.lastIndexOf(',')-1)-1);
if (nmea_sentence[date_stop-2] == '1') {
String date = nmea_sentence.substring(date_stop-2, date_stop);
date = date + nmea_sentence.substring(date_stop-4, date_stop-2);
date = date + nmea_sentence.substring(date_stop-6, date_stop-4);
date = date + nmea_sentence.substring(7, 9);
date = date + ".nme";
date.toCharArray(logfile_name, 13);
Serial.print("File:");
if (!file.open(logfile_name, O_RDWR | O_CREAT | O_AT_END)) {
Serial.println(F("Could not write to SD CARD. Logging disabled."));
hasSDCard = false;
isLogging = true;
file.print(nmea_sentence);
nmea_sentence = "";
default:
switch(checksum_step) {
case 1:
checksum_char = c;
checksum_step = 2;
case 2:
checksum_char ^= c;
case 3:
checksum_string += c;
// periodic stats
if (millis() - timer > 10000) {
Serial.print(F("valid "));
Serial.print(sentences_valid);
Serial.print(F(" / invalid "));
Serial.print(sentences_invalid);
Serial.print(F(" / bytes r "));
Serial.print(bytes_read);
Serial.print(F(" / bytes w"));
Serial.println(bytes_written);
if (hasSDCard) {
// has to be called periodically, otherwise data is not accessible on SD card
file.sync();
timer = millis();
Grüße
Kai
