UDP data not coming through
Hi All,
I'm just testing this code with an ESP8266 (Adafruit Feather Huzzah). It should send simple 'hello_world' via UDP to a raspberry pi...
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
#ifndef STASSID
#include "arduino_secrets.h"
char ssid[] = SECRET_SSID;     // your network SSID (name)
char pass[] = SECRET_PASS;    // your network password (use for WPA, or use as key for WEP)
#endif
byte host[] = {xxx, xxx, x, x}; //redacted
int port = 8888;      // local port to listen on
// buffers for receiving and sending data
//char packetBuffer[UDP_TX_PACKET_MAX_SIZE + 1]; //buffer to hold incoming packet,
char  ReplyBuffer[] = "hello_world\r\n";       // a string to send back
WiFiUDP Udp;
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, pass);
    Serial.print('.');
  Serial.print("Connected! IP address: ");
  //Serial.printf("UDP server on port %d\n", localPort);
  //Udp.begin(localPort);
    // send message to the specified IP address and port
    int A = Udp.beginPacket(host, port);
    Serial.println("Sending UDP packet...");
    Serial.println(A); //returns 1 if udp.beginPacket is succesful, 0 if there is problem with supplied IP address or port.
    Serial.println(ReplyBuffer);
    Udp.write(ReplyBuffer);
    Udp.endPacket();
Code compiles fine, connects to network and seems to be sending data once per second. Also returns A=1, indicating udp.beginPacket is successful.
I'm listening with Netcat on the RPi as follows:
nc -u -l localhost 8888
But I'm not getting anything through.
I can send data over netcat...
nc -u localhost 8888
hello world
comes through fine.
Any thoughts appreciated.
Thanks,
Chris
I used the WiFiUDPClient example from the WiFi library on an ESP32 and with the following line without localhost I received UDP messages.
nc -u -l 8888
