I noticed an odd thing with my UDP sketch. The sketch sends UDPs command to a second UNO. When both the local and the remote Unos 'see' each over the network my sketch runs very quickly.
My UDP code I use is similar to the the SendReceive UDP example:
Udp.beginPacket(Udp.RemoteUnoIP(), Udp.remotePort());
Udp.write(DataCommands);
Udp.endPacket();
As I said if the network connection is working, the sketch sails through this section of the code and the command happens with typical network delays of a few milliseconds.
When I was working on my sketch with no network connection, as the code got to this UDP routine, it took about 2 seconds or so to run. Obviously there is some handshaking taking place between the network and the UDP messaging that stalls if the UDP/network fails. While UDP is a broadcast connectionless type protocol something must delay the routine if it doesn't complete properly. I then connected my Uno to the network so that it saw IP (but it couldn't 'see' the remote Uno as I didn't have it on the LAN). Even with the local Uno having IP the delay was still there.
Does anyone know why the UDP code is waiting? When it stalls, I can see the LED on my Ethernet sheild winking 3 or 4 times during the 2 second stall time. Maybe it is doing some sort of retry loop?
