Udp/EthernetUdp error
I wanted to try to try the IP Gamepad (1) on my Android phone with my Arduino Ethernet. So i downloaded the example (2) and tried to upload it to the Arduino, but i got this error: “The Udp class has been renamed EthernetUdp.”. So i thought I could change “Udp” to “EthernetUdp” (all of them), but then I get this error: “‘EthernetUdp’ was not decleared in this scope”.
What could be wrong? I’m kinda new to Arduino and programming, please help :slight_smile:
LINKS:
  1. IP Gamepad: http://code.google.com/p/ipgamepad/
  2. Example code: http://code.google.com/p/ipgamepad/downloads/detail?name=ArduinoRobotControl_v0.1.zip&can=2&q=
Here’s the example code, “Udp” replaced with “EthernetUdp”:
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <Servo.h>
//Set the MAC address, static IP, gateway, and subnet of the network
byte mac = { 0x00, 0x1D, 0x60, 0xAF, 0x03, 0x35 };
byte ip = { 192, 168, 1, 22 };
//EthernetUdp Stuff
const int PORT = 4444; //Port of incoming EthernetUdp data
const int PACKET_SIZE = 4; //Size of the joystick data packet
byte joystick_data[PACKET_SIZE]; //Byte array for incoming data - [0] = leftY, [1] = leftX, [2] = rightY, [3] = rightX
//Robot specific stuff
boolean lastState = false; //Keeps track of when we go between enabled/disabled or vice versa
unsigned long lastUpdate = 0; //Keeps track of the last time (ms) we received data
//Define outputs
int pwm01 = 5; //Digital Pin 5
int pwm02 = 3; //Digital Pin 3
//Speed Controller/Servo Objects
Servo leftDrive;
Servo rightDrive;
Serial.begin(9600); //Setup serial comms for debugging
// Start Ethernet and EthernetUdp
Ethernet.begin(mac,ip);
EthernetUdp.begin(PORT);
Serial.println(“Control system initialized.”);
xferdata();
//Only allow to be enabled if we’ve received data in the last 100ms and robot is set to enabled
if (((millis() - lastUpdate) <= 100) && (millis() > 500)) // disabled for first 500ms of runtime
enabled();
disabled();
/* This function’s sole purpose is to receive data and shove it into the joystick_data byte array */
void xferdata()
if (EthernetUdp.available()) {
EthernetUdp.readPacket(joystick_data,PACKET_SIZE);
lastUpdate = millis();
void enabled()
//If we were last disabled, we need to attach the PWM outputs
if (lastState == false) {
leftDrive.attach(pwm01);
rightDrive.attach(pwm02);
//Output the left/right drive PWMs based on joystick input (0-180)
leftDrive.write(map((long)joystick_data[0], 0, 255, 0, 180));
rightDrive.write(map((long)joystick_data[2], 0, 255, 0, 180));
//We are enabled
lastState = true;
void disabled()
//disabled, detach PWM outputs
leftDrive.detach();
rightDrive.detach();
//We are disabled
lastState = false;
There are example sketches that come with the Ethernet library with the Arduino IDE. Have you looked at them?
Yes, I've looked at the examples in Arduino, but that one is designed to recieve a "char". It just gives me lots of unreadable signs/letters when I use it with IPGamePad. I've tried to change "char" to "byte", but then I get other errors.
Is anyone able to help me? :slight_smile:
Jomn:
If you are sending bytes in the UDP packet rather than printable characters, then the challenge is in your IPGamePad. It is displaying the character for that value instead of the byte value. Try reprogramming the IPGamePad, or convert the byte values to an asciii string before sending it.
try this
  Arduino Based Robot Control System v0.1
  by Eric Barch (ttjcrew.com)
#include <SPI.h>
#include <Servo.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[]  = { 192, 168, 1, 55 };
//UDP Stuff
unsigned int localPort = 55;            //Port of incoming UDP data
//Define robot outputs
int pwm02 = 6;  //Digital Pin 6
Servo leftDrive;
Servo rightDrive;
EthernetUDP Udp;
  // Start Ethernet and UDP
  Udp.begin(localPort);
  Serial.println("Robot control system initialized.");
    xferdata();
    //Only allow robot to be enabled if we've received data in the last 100ms and robot is set to enabled
    if (((millis() - lastUpdate) <= 100) && (millis() > 500))  //Robot is disabled for first 500ms of runtime
      enabled();
      disabled();
/* This function's sole purpose is to receive data and shove it into the joystick_data byte array */
void xferdata()
  if (Udp.available()) {
    Udp.read(joystick_data,PACKET_SIZE);
void enabled()
    //We are enabled
    lastState = true;
void disabled()
    //Robot is disabled, detach PWM outputs
    leftDrive.detach();
    //We are disabled
    lastState = false;
Pittom
Had the same problems and your solution worked - thanks
Bruce
I compile this code, but error, show where I found Udp.h library?
thanks
#include <SPI.h>
#include <Udp.h>
byte mac = {0x90, 0xa2, 0xda, 0x00, 0x23, 0x16};
byte ip = {10, 10, 5, 124};
const unsigned int localPort = 1369;
char recvdBuffer[UDP_TX_PACKET_MAX_SIZE + 1];
char replyBuffer[UDP_TX_PACKET_MAX_SIZE + 1];
byte remoteIp[4];
unsigned int remotePort;
const int ledPin = 9;
Ethernet.begin(mac, ip);
pinMode(ledPin, OUTPUT);
int recvdSize = Udp.available();
if (recvdSize)
Udp.readPacket(recvdBuffer, UDP_TX_PACKET_MAX_SIZE, remoteIp, remotePort);
recvdBuffer[recvdSize] = ‘\0’;
recvdSize -= 8;
Serial.print("Received packet data size = “);
Serial.print(recvdSize);
Serial.print(” from ");
for (int i = 0; i < 4; i++)
Serial.print(remoteIp*, DEC);*
  • if (i < 3)*
  • Serial.print(".");*
  • Serial.print(", port number ");*
  • Serial.println(remotePort);*
  • Serial.print("Contents: ");*
  • Serial.println(recvdBuffer);*
  • switch (recvdBuffer[0])*
  • case ‘H’:*
  • Serial.println(“Turning LED on”);*
  • digitalWrite(ledPin, HIGH);*
  • strncpy(replyBuffer, “H: LED is On”, UDP_TX_PACKET_MAX_SIZE);*
  • break;*
  • case ‘L’:*
  • Serial.println(“Turning LED off”);*
  • strncpy(replyBuffer, “L: LED is Off”, UDP_TX_PACKET_MAX_SIZE);*
  • digitalWrite(ledPin, LOW);*
  • break;*
  • default:*
  • Serial.println(“No action”);*
  • strncpy(replyBuffer, “Unknown command”, UDP_TX_PACKET_MAX_SIZE);*
  • break;*
  • Udp.sendPacket(replyBuffer, remoteIp, remotePort);*
// change this
#include <Udp.h>
// to this
