I am trying to send GPS-Data from one ESP8266 to another ESP8266 via UDP. I am using the WiFiUdp library. But I have noticed something weird. The packet gets sent from one device to the other, but whenever there is a zero byte in the packet, all the data in this packet after the zero byte becomes zero.
Example:
Sent packet: 2E BE 00 4D 21
Received packet: 2E BE 00 00 00
Sent packet: 2E BE FF 4D 21
Received packet: 2E BE FF 4D 21
If I send a packet without a zero byte everything is fine. Can somebody explain to me why this happens? And what would be a way to handle this?
Thanks!
This is basically the code that sends the packet. Examples of the print:
Example 1: "Sensor Answer: 12 34 56 78 9A BC DE F6"
Example 1: "Sensor Answer: 12 34 56 78 00 BC DE F6"
And this is the code that receives the packet. Examples of the print with the packets sent by the examples above:
Example 1: "ListenClient::2 Bytes read: 10 Sensor Answer: 12 34 56 78 9A BC DE F6"
Example 2: "ListenClient::2 Bytes read: 10 Sensor Answer: 12 34 56 00 00 00 00 00"
Ok, the size is 3 according to the print.
It is quite hard to give a full example of the working code as it is quite long, because there is a lot more functions. But the only thing that is producing this error, is if there is a byte with 00.
What I am doing is basically chopping the GPS data and time data up into bytes which can be send via the packet. The receiver then puts the data back together and saves it onto a SD card. This works fine, except for when the 00 thing happens.
I have changed the send packet to: 0x12 34 50 08 9A BC DE F6, so that it should get send normally and it does. This is what the changes you advised to me printed:
Packet size: 28
12 34 50 08 9A BC DE F6 14 04 CE 17 63 53 6A 00 00 00 00 00 00 00 00 00 F0 A7 C6 4B
Then post a Minimum Reproducible Example (MRE). That is the smallest possible code that compiles and demonstrates the problem. Leave out all the unrelated stuff from your big, messy code.
So this is the code that basically puts the GPS and time data into single bytes in hex. It is a little bit confusing but it works. I am sure that there are better ways to do it, but that is how I have done it. The array "arr" is the the array "answerPacketData", that gets send to the receiver via UDP. Nothing else is done with "answerPacketData". So as you can see there are a max of 10 Bytes in it.
Hope this helps.
void MSG_encode(char* arr, uint16_t& ip, uint64_t& data_val_64, uint16_t& time_val)
uint16_t rest = 0;
uint16_t rest_lat = 0;
uint16_t rest_long = 0;
uint16_t quotient_data = 0;
uint16_t quotient_time = 0;
uint32_t quotient_data_lat = 0;
uint32_t quotient_data_long = 0;
quotient_data_long = (uint32_t)data_val_64 & 0xFFFFFFFF; //this is just a conversion to the decimal value of the longitudinal value
quotient_data_lat = (uint32_t)(data_val_64>>32) & 0xFFFFFFFF; //this is just a conversion to the decimal value of the latidunal value
quotient_time = time_val;
/* Sensor Data und Timevalue conversation, Slave to Master */
uint8_t t_arr[16] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}; // Slave send Data, convert to Hex
for (uint8_t i=0; i < 8; i++)
rest_lat = quotient_data_lat %16;
quotient_data_lat = quotient_data_lat /16;
rest_long = quotient_data_long %16;
quotient_data_long = quotient_data_long /16;
t_arr[i] = rest_lat;
t_arr[i+8] = rest_long;
//Serial.printf("MSG_encode::3:: t_arr[%d]:%4X\n\r",i, arr[i]);
arr[0] = (t_arr[7]<<4) | t_arr[6];
arr[1] = (t_arr[5]<<4) | t_arr[4];
arr[2] = (t_arr[3]<<4) | t_arr[2];
arr[3] = (t_arr[1]<<4) | t_arr[0];
arr[4] = (t_arr[15]<<4) | t_arr[14];
arr[5] = (t_arr[13]<<4) | t_arr[12];
arr[6] = (t_arr[11]<<4) | t_arr[10];
arr[7] = (t_arr[9]<<4) | t_arr[8];
rest = 0;
t_arr[0] = 0x00;
t_arr[1] = 0x00;
t_arr[2] = 0x00;
t_arr[3] = 0x00;
t_arr[4] = 0x00;
t_arr[5] = 0x00;
for (uint8_t i=0; i<4; i++)
rest = quotient_time %16;
quotient_time = quotient_time /16;
t_arr[i] = rest;
arr[8] = (t_arr[1]<<4) | t_arr[0];
arr[9] = (t_arr[3]<<4) | t_arr[2];
you probably would be better off using a structure and sending the bytes in the structure directly rather than going through all those modifications
we would need to see a code with c_UDP.write(answerPacketData, 10); to ensure you only send 10 bytes and a receiver code with what I provided above (that should see the 10 bytes coming in)
I don't really know what I have changed but I guess it had somethind to do with the c_UDP.write(answerPacketData, 10); and now it works! Thanks a lot for the patience and help!
