UDP Receive funny outputs from arduino numeric input
Ive been working on an arduino project where the sensor from arduino will broadcast input to the ethernet thru UDP and the computer will receives the UDP packets on the other end. The connection is fine and I can receive the data well using normal analogread method.
However, I would like to try this oversampling method from ElectricRCAircraftGuy; but when i did so, i started to receiving wierd symbol on the receiving side (C#) whereas the arduino serial monitor still shows numeric inputs.
Here are a few pictures to help better understand the situation: http://imgur.com/a/0BJSx
Any help is deeply appreciated thank you!
Post your code & sample output here, as text, not as pictures on some image hosting site. Read the forum rules to find out how to do those things.
Hi, Welcome to the forum.
Please read the first post in any forum entitled how to use this forum. http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code. It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.. :)
