Hello,
So I have been working on a project andhave successfully managed to read a UDP string from packet sender to send out artnet data that is successfully read by artnetominator
However I have been going round in circles with the next step;
The sketch works to send a hard value on receiving data however i would like it to fade from 0 (or pre defined value) to the temp_val
currently the snippet below will send a value of 100 to buffer_dmx[1] which is the first channel. what would be the best approach to get this to fade from 0 - 100 over 5 seconds for example ?
The full code it attached below.
void SendArtnet(){
if(strcmp(packetBuffer,"Test")==0){
Serial.println("message recieved Channel 1");
int temp_val=1;
buffer_dmx[1]=byte(temp_val*100);
Chaned some things for Arduino 1.0
ARTNET SENDER
#include <SPI.h> // needed for Arduino versions later than 0018
#include <Ethernet.h>
#include <EthernetUdp.h> // UDP library from: bjoern@cs.stanford.edu 12/30/2008
//MAC and IP of the ethernet shield
//MAC adress of the ethershield is stamped down the shield
//to translate it from hexa decimal to decimal, use: http://www.frankdevelopper.com/outils/convertisseur.php
//TO EDIT:
// the next two variables are set when a packet is received
byte destination_Ip[]= { 255,255,255,255 }; // the ip to send data, 255,255,255,255 is broadcast sending
// art net parameters
unsigned int localPort = 6454; // artnet UDP port is by default 6454
const int DMX_Universe=0;//universe is from 0 to 15, subnet is not used
const int number_of_channels=4; //512 for 512 channels, MAX=512
// buffers for receiving and sending data
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; // buffer to hold incoming packet,
//char ReplyBuffer[] = "acknowledged"; // a string to send back
//HARDWARE
byte mac[] = { 144, 162, 218, 00, 16, 96 };//the mac adress of ethernet shield or uno shield board
byte ip[] = { 2,0,0,116 };// the IP adress of your device, that should be in same universe of the network you are using, here: 192.168.1.x
//ART-NET variables
char ArtNetHead[8]="Art-Net";
const int art_net_header_size=17;
short OpOutput= 0x5000 ;//output
byte buffer_dmx[number_of_channels]; //buffer used for DMX data
EthernetUDP Udp;
//Artnet PACKET
byte ArtDmxBuffer[(art_net_header_size+number_of_channels)+8+1];
//initialise artnet header
construct_arnet_packet();
// démarrage ethernet et serveur UDP
Ethernet.begin(mac,ip);
Udp.begin(localPort);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// Check for Ethernet hardware present
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
while (true) {
delay(1); // do nothing, no point running without Ethernet hardware
if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable is not connected.");
SendArtnet();
Udp.beginPacket(destination_Ip, localPort);
Udp.write(ArtDmxBuffer,(art_net_header_size+number_of_channels+1)); // was Udp.sendPacket
Udp.endPacket();
delay(40);
// if there's data available, read a packet
int packetSize = Udp.parsePacket();
if (packetSize) {
Serial.print("Received packet of size ");
Serial.println(packetSize);
Serial.print("From ");
IPAddress remote = Udp.remoteIP();
for (int i=0; i < 4; i++) {
Serial.print(remote[i], DEC);
if (i < 3) {
// Serial.print(".");
Serial.print(", port ");
Serial.println(Udp.remotePort());
// read the packet into packetBufffer
Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
Serial.println("Contents:");
Serial.println(packetBuffer);
void SendArtnet(){
int temp_val=1;
int temp_val1=2;
buffer_dmx[2]=byte(temp_val*10);
Serial.println(buffer_dmx[1]);
if(strcmp(packetBuffer,"Test2")==0){
Serial.println("message recieved Channel 2");
int temp_val=1;
int temp_val1=2;
buffer_dmx[1]=byte(temp_val*10);
delay(10);
for(int i=0;i<UDP_TX_PACKET_MAX_SIZE;i++) packetBuffer[i] = 0;
void construct_arnet_packet()
//preparation pour tests
for (int i=0;i<7;i++)
ArtDmxBuffer[i]=ArtNetHead[i];
//Operator code low byte first
ArtDmxBuffer[8]=OpOutput;
ArtDmxBuffer[9]= OpOutput >> 8;
//protocole
ArtDmxBuffer[10]=0;
ArtDmxBuffer[11]=14;
//sequence
ArtDmxBuffer[12]=0;
//physical
ArtDmxBuffer[13] = 0;
// universe
ArtDmxBuffer[14]= DMX_Universe;//or 0
ArtDmxBuffer[15]= DMX_Universe>> 8;
//data length
ArtDmxBuffer[16] = number_of_channels>> 8;
ArtDmxBuffer[17] = number_of_channels;
for (int t= 0;t<number_of_channels;t++)
ArtDmxBuffer[t+art_net_header_size+1]=buffer_dmx[t];
lots of credit to Christoph Guillermet for the artnet implimenation
