I have a program that needs to output data over ethernet using UDP.write(). The data consists of a variety of variable types, and I am getting a lot of errors about the types. The code block that is giving me trouble is below.
UDP.write("Art-Net"); // packet descriptors
UDP.write(0x00);
UDP.write(0x00, 0x21); // op-code
UDP.write(IP); // IP address
UDP.write(0x36, 0x19); // port
UDP.write(0x00, 0x01); // firmware version
UDP.write(0x00, 0x00); // net, subnet, universe
UDP.write(0x03, 0x62); // OEM code
UDP.write(0x00); // UBEA version
UDP.write(0xD0); // status
UDP.write("AV"); // manufacturer code
UDP.write("4-port node ", 0x00); // short name
UDP.write(" "); // long name
UDP.write("#", 0x00, 0x01, " [" + artPollCount, "] "); // node report
UDP.write(0x00, 0x04); // number of ports
UDP.write(0x80, 0x80, 0x80, 0x80); // port modes
UDP.write(0x08, 0x08, 0x08, 0x08); // inputs
UDP.write(0x80, 0x80, 0x80, 0x80); // outputs
UDP.write(0x00, 0x00, 0x00, 0x00); // input universes
UDP.write(0x00, 0x01, 0x02, 0x03); // output universes
UDP.write(0x00, 0x00, 0x00); // video, macro, remote
UDP.write(0x00, 0x00, 0x00); // spares
UDP.write(0x00); // device type
UDP.write(MAC); // MAC address
UDP.write(0x00, 0x00, 0x00, 0x00, 0x00);// binding
UDP.write(0x08); // addressing
UDP.write(0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); // filler
The error messages generated by the compiler are below.
[/size]Artnet_to_DMX.cpp: In function ‘void loop()’:
Artnet_to_DMX:72: error: call of overloaded ‘write(int)’ is ambiguous
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/EthernetUdp.h:69: note: candidates are: virtual size_t EthernetUDP::write(uint8_t)
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Print.h:49: note: size_t Print::write(const char*)
Artnet_to_DMX:75: error: invalid conversion from ‘int’ to ‘const uint8_t*’
Artnet_to_DMX:75: error: initializing argument 1 of ‘virtual size_t EthernetUDP::write(const uint8_t*, size_t)’
Artnet_to_DMX:78: error: invalid conversion from ‘int’ to ‘const uint8_t*’
Artnet_to_DMX:78: error: initializing argument 1 of ‘virtual size_t EthernetUDP::write(const uint8_t*, size_t)’
Artnet_to_DMX:79: error: call of overloaded ‘write(int)’ is ambiguous
Artnet_to_DMX:82: error: invalid conversion from ‘const char*’ to ‘const uint8_t*’
Artnet_to_DMX:82: error: initializing argument 1 of ‘virtual size_t EthernetUDP::write(const uint8_t*, size_t)’
Artnet_to_DMX:84: error: no matching function for call to ‘EthernetUDP::write(const char [2], int, int, const char*, const char [56])’
/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/EthernetUdp.h:71: note: virtual size_t EthernetUDP::write(const uint8_t*, size_t)
Artnet_to_DMX:86: error: no matching function for call to ‘EthernetUDP::write(int, int, int, int)’
Artnet_to_DMX:87: error: no matching function for call to ‘EthernetUDP::write(int, int, int, int)’
Artnet_to_DMX:88: error: no matching function for call to ‘EthernetUDP::write(int, int, int, int)’
Artnet_to_DMX:89: error: no matching function for call to ‘EthernetUDP::write(int, int, int, int)’
Artnet_to_DMX:90: error: no matching function for call to ‘EthernetUDP::write(int, int, int, int)’
Artnet_to_DMX:91: error: no matching function for call to ‘EthernetUDP::write(int, int, int)’
Artnet_to_DMX:92: error: no matching function for call to ‘EthernetUDP::write(int, int, int)’
It looks like I am trying to pass an incorrect data type to write(), but I don’t know how to fix it. I’m sure it’s fairly simple, but I’m pretty new to c++.
