Change-log for version 0.8.5e
833c432 Fixed compile abort on sketch error
I bug in the compiler system meant that if the sketch (which is compiled
first in the list) has an error the compilation continued right to the end
resulting in the error being lost up the top of the output. It now aborts
the compilation immediately the sketch compilation fails.
2a7cf68 Created basic sketch backup system
You now have the option to, when saving your sketch, to create a number
of backup copies. The number (and the option) to save is in preferences,
and if enabled, it keeps the last N versions of your sketch files in a
"backup" folder inside the sketch. The backups are named -1
through to -N, with -1 being the most recent copy. At the
moment it only backs up the files that are able to be edited directly by
the IDE, so doesn't include sketch libraries, binary files, etc.
3b87588 Better default Linux sketchbook location
The Linux version now doesn't prompt for a sketchbook location the
first time you start the program. Instead it now, like the other
platforms, creates a "UECIDE" folder in your documents folder
(/home/foo/Documents/UECIDE) for your sketches. Of course, if you
already have a sketchbook folder elsewhere set up in the preferences.txt
file, it will keep using that.
86f348b Removed the windows JRE from the repo
The JRE distribution is now stored online at
http://uecide.org/support/jre-7-windows.zip
This makes tarball downloads of the repository considerably smaller.
The repository will also be pruned to remove the large files
historically too.
3ade2a5 Added version.plist file generation
When compiling UECIDE outside of git (say from a downloaded tarball)
the version information is not available. Now, if it's not being
compiled inside git, the version information is obtained from a
version.plist file. That file is updated automatically by the
build script when compiled from within git.
23bbb97 Porting to FreeBSD
This is the start of an effort to port UECIDE cleanly to FreeBSD, including
the ability to build and package it through the FreeBSD ports system.
518dbc9 Removed early jre version
There was a left-over large zip file of JRE 6 for windows hanging
around in the Windows dist folder. It has been removed.
