UG8lib bitmap understanding
So after two weeks I finally got my 128*64 dot matrix display to function using the UG8lib. inside the example code provided with the library is one called Bitmap provided below for convenience. Now what I wish to understand is how would one write a an image into it for display? examples being game sprites like sonic or mario, again for example and practice. can someone explain it at all? I understand its binary conversion, not unlike writing for a commodore 64, but I personally never learned how to do that, anyway any advice would be greatly appreciated.
  Bitmap.pde
  Show simple bitmap
  >>> Before compiling: Please remove comment from the constructor of the
  >>> connected graphics display (see below).
  Universal 8bit Graphics Library, https://github.com/olikraus/u8glib/
  Copyright (c) 2011, olikraus@gmail.com
  All rights reserved.
  Redistribution and use in source and binary forms, with or without modification,
  are permitted provided that the following conditions are met:
  * Redistributions of source code must retain the above copyright notice, this list
    of conditions and the following disclaimer.
  * Redistributions in binary form must reproduce the above copyright notice, this
    list of conditions and the following disclaimer in the documentation and/or other
    materials provided with the distribution.
  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
  CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,
  INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
  MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
  CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
  NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
  LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
  STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
  ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
  ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "U8glib.h"
// setup u8g object, please remove comment from one of the following constructor calls
// IMPORTANT NOTE: The following list is incomplete. The complete list of supported
// devices with all constructor calls is here: https://github.com/olikraus/u8glib/wiki/device
U8GLIB_ST7920_128X64_1X u8g(12, 10, 11); // SPI Com: SCK = en = 18, MOSI = rw = 16, CS = di = 17
//U8GLIB_ST7920_128X64_4X u8g(18, 16, 17); // SPI Com: SCK = en = 18, MOSI = rw = 16, CS = di = 17
//U8GLIB_ST7920_192X32_1X u8g(8, 9, 10, 11, 4, 5, 6, 7, 18, 17, 16);   // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7 en=18, di=17,rw=16
//U8GLIB_ST7920_192X32_4X u8g(8, 9, 10, 11, 4, 5, 6, 7, 18, 17, 16);   // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7 en=18, di=17,rw=16
//U8GLIB_ST7920_192X32_1X u8g(18, 16, 17); // SPI Com: SCK = en = 18, MOSI = rw = 16, CS = di = 17
const uint8_t rook_bitmap[] PROGMEM = {
  0x00,         // 00000000
  0x55,         // 01010101
  0x7f,          // 01111111
  0x3e,         // 00111110
  0x3e,         // 00111110
  0x3e,         // 00111110
  0x3e,         // 00111110
  0x7f           // 01111111
void draw(void) {
  // graphic commands to redraw the complete screen should be placed here
  u8g.drawBitmapP( 0, 0, 1, 8, rook_bitmap);
void setup(void) {
void loop(void) {
  // picture loop
  u8g.firstPage();
  do {
    draw();
  } while( u8g.nextPage() );
  // rebuild the picture after some delay
I've never used UG8lib, but other OLED libraries I've tried, use XBMs (X BitMaps).
You can easily use GIMP to export an image to XBM.
Pieter
unfortunately the display I use has no support for a SD card or microSD, though I'm sure an SD card shield would remedy that, but for that to work I'd need another library (for sanity's sake) that supports an LCD using the ST7920 chipset
You don't need an SD card, it's a C array, you can just save it to progmem (that's what they do in the example you posted).
Pieter
