//PatternSeq1();
if(LEDValue==7) LEDValue=0;
Serial.print(LEDValue);
Serial.print(":");
// Serial.println(
Display(LEDValue);
delay(4000);
LEDValue++;
int terminator(byte req[])
int n = 0;
int v;
v = req[n];
while (v!=0)
// Serial.println(v); //does not stop when it hits 0 in the array?!
n++;
v = req[n];
return n-1;
void Display(byte Val)
int items,V,n = 0;
Clear();
// Serial.print("Items: ");
// Serial.print(items);
// Serial.println("");
// Serial.print("V: ");
// Serial.println(V);
switch(Val)
case 0: { items=terminator(v0); for(n=0; n<=items; n++) digitalWrite(v0[n],HIGH); }
case 1: { items=terminator(v1); for(int n=0; n<=items; n++) { digitalWrite(v1[n],HIGH); }}
case 2: { items=terminator(v2); for(int n=0; n<=items; n++) { digitalWrite(v2[n],HIGH); }}
case 3: { items=terminator(v3); for(int n=0; n<=items; n++) { digitalWrite(v3[n],HIGH); }}
case 4: { items=terminator(v4); for(int n=0; n<=items; n++) { digitalWrite(v4[n],HIGH); }}
case 5: { items=terminator(v5); for(int n=0; n<=items; n++) { digitalWrite(v5[n],HIGH); }}
case 6: { items=terminator(v6); for(int n=0; n<=items; n++) { digitalWrite(v6[n],HIGH); }}
// case 7: { items=sizeof(v6); for(int n=0; n<=items; n++) digitalWrite(v7[n],HIGH); }
delay(5000);
void Clear()
int n;
for(n=2; n<=9;)
digitalWrite(n,LOW);
delay(50);
n++;
sorry for the mess (been trying for hours to work this out)
basically, the code above is the issue, quite simple, it runs through an array of bytes, {2,3,4,5,0} because i could not find a "how many in array function" i simply
appended 0 in the array.
- how many elements in the array
- switch on pins in that array.
int n = 0;
int v;
v = req[n];
while (v!=0)
n++;
v = req[n];
return n-1;
is simply returning an invalid number eg 2,3,4,0 = 3 (meaning, pins 2,3,4 need to be switched on) the 0 does not seem to be found.
full code
byte v0[] = {2,3,0};
byte v1[] = {3,4,0};
byte v2[] = {5,6,7,0};
byte v3[] = {8,9,0};
byte v4[] = {2,0};
byte v5[] = {2,0};
byte v6[] = {2,0};
//byte v2[] = {8,9,5,2,3};
//byte v3[] = {2,3,4,5,6,7,8,9};
byte LEDValue = 0;
int n;
for(n=2; n<=9; n++)
pinMode(n,OUTPUT);
//PatternSeq1();
Serial.print(":");
// Serial.println(
Display(LEDValue);
delay(4000);
LEDValue++;
int n = 0;
int v;
v = req[n];
while (v!=0)
n++;
v = req[n];
return n-1;
int items,V,n = 0;
Clear();
switch(Val)
delay(5000);
void Clear()
int n;
for(n=2; n<=9;)
delay(50);
n++;
void PatternSeq1()
int n;
for(n=2; n<=9; n++)
digitalWrite(n,HIGH);
delay(5500);
for(n=9; n>=2; n--)
LEDface.ino (1.95 KB)
