Ich suche eine Billige Methode die Uhrzeit herauszufinden (auf dem Arduino). Die habe ich gefunden:
#define secondPin 4
#define minutePin 5
#define hourPin 6
#define weekdayPin 7
int second=0, minute=0, hour=0, weekday=1;
pinMode(secondPin, INPUT);
pinMode(minutePin, INPUT);
pinMode(hourPin, INPUT);
pinMode(weekdayPin, INPUT);
static unsigned long lastTick = 0;
if (millis() - lastTick >= 1000) {
lastTick = millis();
serialOutput();
second++;
if (second > 59) {
minute++;
second = 0;
if (minute > 59) {
hour++;
minute = 0;
if (hour > 23) {
weekday++;
hour = 0;
if (weekday > 7) {
weekday = 1;
checkButtons();
void checkButtons() {
if (digitalRead (secondPin)==HIGH) {
second++;
if (digitalRead (minutePin)==HIGH) {
minute++;
if (digitalRead (hourPin)==HIGH) {
hour++;
if (digitalRead (weekdayPin)==HIGH) {
weekday++;
void printWeekday (int dayNum) {
// print a weekday, based on the day number
switch (dayNum) {
case 1:
Serial.print ("Sonntag");
case 2:
Serial.print ("Montag");
case 3:
Serial.print ("Dienstag");
case 4:
Serial.print ("Mittwoch");
case 5:
Serial.print ("Donnerstag");
case 6:
Serial.print ("Freitag");
case 7:
Serial.print ("Samstag");
void serialOutput() {
// this function creates a clock you can read through the serial port
// your clock project will have a MUCH more interesting way of displaying the time
// get creative!
printWeekday(weekday); // picks the right word to print for the weekday
Serial.print(", "); // a comma after the weekday
Serial.print(hour, DEC); // the hour, sent to the screen in decimal format
Serial.print(":"); // a colon between the hour and the minute
Serial.print(minute, DEC); // the minute, sent to the screen in decimal format
Serial.print(":"); // a colon between the minute and the second
Serial.println(second, DEC); // the second, sent to the screen in decimal format
Aber die Methode ist irgend wie Merkwürzig gibt es eine billige Hardware Lösung? ich kenne das Real Time Shield aber auf watterott kostet das 16 €
Kennt jemand einen Chip der so was Drauf hat? (links von watterott und conrad sind gern gesehen^^)
