'Ui' was not declared in this scope
I added a line what I like to have is to sign the distance to U i, i = 0, 1, 3, how should I do it please?
Thanks
Adam
#include <NewPing.h>
#define SONAR_NUM 3      // Number of sensors.
#define MAX_DISTANCE 200 // Maximum distance (in cm) to ping.
NewPing sonar[SONAR_NUM] = {   // Sensor object array.
  NewPing(10, 11, MAX_DISTANCE), // Each sensor's trigger pin, echo pin, and max distance to ping.
  NewPing(12, 13, MAX_DISTANCE),
  NewPing(8, 9, MAX_DISTANCE)
uint8_t currentSensor = 0;
uint8_t U = 0;
unsigned int cm[SONAR_NUM];
  Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
  for (uint8_t i = 0; i < SONAR_NUM; i++) { // Loop through each sensor and display results.
    delay(50); // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
    ///// Serial.print("U");
    Serial.print(i);
    Serial.print("=");
    Serial.print(sonar[i].ping_cm());
    Serial.print("cm ");
    Ui = sonar[i].ping_cm();
ERROR:
Arduino: 1.8.3 (Windows 7), Board: "Arduino/Genuino Uno"
C:\Users\HUA.DELLV-PC\Documents\Arduino\newping.1\newping.1.ino: In function 'void loop()':
newping.1:35: error: 'Ui' was not declared in this scope
exit status 1
option enabled in File -> Preferences.
Ok, show us the line where "Ui" is declared.
Paul
Thanks.
"U" is declared in front, and ,' i' is declared in for. How to use them together?
Take this Forum as example:
there's the user
Paul_KD7HB
and there is the user
shanren
but there is no user
Paul_KD7HBshanren
The same is true with your variables.
What do you want to get in the end?
What value do you want Ui to contain, particularly as it is never used in the sketch ?
Do you perhaps have in mind to declare U as an array and then to store values in it indexed by the value of i ?
Thanks.
The newping gives out distances measured without a name, I want to use the result say U0 / U1 /U2 later on.
than you would need to declare and use an Array
Did you mean 'U'?
Edit: slow response.
Please Unlike this response.
You cannot invent variable names at runtime but you could use an array U[3] and hold values in the array addresses of U[0], U[1] and U[2]
yes.
You really should check the return type of ping_cm - 255xm.isnt that far, and a sensor could return a valid, bigger value.
And you really should ping just once, and store the result.
Thanks.
The question here is how to store the result?
Could that be the answer?
Thanks.
uint8_t U = 0; changed into: uint8_t U[3] = {0}; works.
