Hi Everyone,
I've been stuck on this problem for a while and couldn't figure anything out. My setup is that I have an Arduino Nano with an ESP01 onboard that reads from a socket hosted by my computer. The socket sends headers that have a constant length of 64 bytes. The issue here, is that after I read the data from the socket and save it to a buffer, and when I write it to Serial with Serial.write(), it's fine and it's the message that got sent through the socket.
However, I noticed, that immediately afterwards if you read it again to Serial, it's total garbage data, even though it should still be in scope.
Here's the relevant section
while (client.connected()) {
Serial.println("Waiting for message...");
int i = 0;
while (client.available() > 0) {
if (i == HEADER_SIZE) {
i = 0;
header_buffer[i] = client.read();
Serial.write(header_buffer[i]);
received_message = true;
if (received_message) {
Serial.println("");
received_message = false;
for (int j = 0; j < HEADER_SIZE; ++j) {
Serial.write(header_buffer[j]);
Serial.println("");
note that header and received_message are initialized at the start of void loop()
uint8_t header_buffer[HEADER_SIZE];
bool received_message = false;
First it prints out 0123456789abcdefghijklmopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ!@^, which is exactly the contents of the packet I sent,
but then 5E2AC101839FD8F7EF1FFE7ED5FB77EDBE7B9CFECFACFEFDEF5FD7FBD597F7FFFFF745FB8DDFFFF7DF94FFBFDFFFAFFFFFD7FBFD78FFFFF771DEE3FF79DF31 afterwards. (I did put it in hex for the forum), which is even the wrong length (63).
I'm at a total loss of what I'm doing wrong, and help is much appreciated.
