uint8_t and BIN
uint8_t data[16];
i need get value from data as BIN ( 67 bit )
Please some example,
You need to get 67 bit data from a 128 bit data set?
8 bits.
Oops.
igorvukotic:
I’m not sure that is possible. Why do you want to?
http://xyproblem.info/
i have 128 BITs, so i need to evalute 67 BIT state.... ( only one bit )
igorvukotic: i have 128 BITs, so i need to evalute 67 BIT state.... ( only one bit )
Nope, still not getting it.
HEX 00 00 03 90 84 30 65 45 2B 80 00 00 00 00 00 00
BIN 00000000000000000000000000000011000010010000000010000100000000110{0}0000000110010100000100010100000010101100001000000000000000000000000000000000000000000000000000000000000000000000000000
evalute BIT state in {}
You probably want to use the division ('/') and modulo ('%') operators to locate the correct byte and bit, and then use bitRead to get the value of the bit you're interested in.
My BitBool library makes this fairly simple. http://forum.arduino.cc/index.php?topic=128407.0
There are a few ways of doing what you want, here is one:
#include <BitBool.h>
uint8_t data[16];
typedef BitBool< 128 > BITS;
  BITS &bits = *(BITS*) data;
  bool bitValue = bits[ 67 ];
void loop() {}
uint8_t data[16];
Gives you 16 8 bit values, or 128 bits Bit 67 of the whole array is bit 4 of data[8] so to read it you can use
bitRead(data[8], 4);
igorvukotic: HEX 00 00 03 90 84 30 65 45 2B 80 00 00 00 00 00 00
I don't understand this either. What does evaluate mean? Look, tell us what you are trying to solve, not how you want to evaluate bits.
Thanks pYro_65 & UKHeliBob Thats exactly what i need
