uint8_t converting to readable text?
I have this: uint8_t key[] = {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31};
How can I convert it to char or something so that I can read its contents?
have you used sprintf() ?
Typical example:
char myStr[10];  // a buffer
int myInt = 3; // a number
sprintf(myStr, %d,myInt); //convert
Serial.println(myStr);
Well if those numbers are supposed to actually be ascii chars, then you can't.
Ascii values 0 to 20 are not readable text, they are control characters.
michinyon:
Well if those numbers are supposed to actually be ascii chars, then you can’t.
following on from that it is also very simple to print an array of ascii values to serial monitor
for (int i = 0; i < sizeof(key); i++){
     Serial.write(key[i]);
using write instead of print makes a difference - see the arduino documentation for the two :slight_smile:
