Hi all, I've been working with this barcode scanner code from this website:
From what I understand, it takes the acsii input from the barcode scanner and outputs it into readable characters to the LCD screen. This part isn't a problem, it all works, but I want to manipulate that code to read that acsii string, match it to a set, and print out a different number to the lcd screen based off of that comparison. My only problem is finding out how to read that key
I've tried setting an if statement as follows:
if(key == (48,50,56,52,48,48,48,48,51,48,48,49,19)
key == (49)
That key is an actual barcode that I have scanned, I'm trying to convert it to another number before it prints using the (char)key function. This code compiles fine, but it doesn't execute this if statement, it just continues to print the same corresponding acsii-> character translation to: 028400003001 on the lcd screen
Am I just reading the key wrong in the if statement?? Do I need to store it as a variable first?
Any help is much appreciated, thanks!
Here's the actual code:
Portable barcode scanner. Uses USB HID barcode scanner, Arduino Board, USB Host Shield and HD44780-compatible LCD display
The circuit:
- LCD RS pin to digital pin 7
- LCD Enable pin to digital pin 6
- LCD D4 pin to digital pin 5
- LCD D5 pin to digital pin 4
- LCD D6 pin to digital pin 3
- LCD D7 pin to digital pin 2
- LCD R/W pin to ground
- 10K resistor:
- ends to +5V and ground
- wiper to LCD VO pin (pin 3)
#include <hid.h>
#include <hiduniversal.h>
#include <LiquidCrystal.h>
#include <avr/pgmspace.h>
//#include <avrpins.h>
//#include <max3421e.h>
//#include <usbhost.h>
//#include <usb_ch9.h>
#include <Usb.h>
#include <usbhub.h>
//#include <address.h>
#include <hidboot.h>
//#include <printhex.h>
//#include <message.h>
//#include <hexdump.h>
//#include <parsetools.h>
#define DISPLAY_WIDTH 16
// initialize the LCD library with the numbers of the interface pins
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
USB Usb;
USBHub Hub(&Usb);
HIDUniversal Hid(&Usb);
HIDBoot<HID_PROTOCOL_KEYBOARD> Keyboard(&Usb);
class KbdRptParser : public KeyboardReportParser
void PrintKey(uint8_t mod, uint8_t key);
protected:
virtual void OnKeyDown (uint8_t mod, uint8_t key);
virtual void OnKeyPressed(uint8_t key);
void KbdRptParser::OnKeyDown(uint8_t mod, uint8_t key)
uint8_t c = OemToAscii(mod, key);
if (c)
OnKeyPressed(c);
/* what to do when symbol arrives */
void KbdRptParser::OnKeyPressed(uint8_t key)
static uint32_t next_time = 0; //watchdog
static uint8_t current_cursor = 0; //tracks current cursor position
if( millis() > next_time ) {
lcd.clear();
current_cursor = 0;
delay( 5 ); //LCD-specific
lcd.setCursor( 0,0 );
}//if( millis() > next_time ...
next_time = millis() + 200; //reset watchdog
if( current_cursor++ == ( DISPLAY_WIDTH + 1 )) { //switch to second line if cursor outside the screen
lcd.setCursor( 0,1 );
Serial.println( (char)key );
lcd.print( (char)key );
KbdRptParser Prs;
Serial.begin( 115200 );
Serial.println("Start");
if (Usb.Init() == -1) {
Serial.println("OSC did not start.");
delay( 200 );
Hid.SetReportParser(0, (HIDReportParser*)&Prs);
// set up the LCD's number of columns and rows:
lcd.begin(DISPLAY_WIDTH, 2);
lcd.clear();
lcd.noAutoscroll();
lcd.print("Ready");
delay( 200 );
Usb.Task();
