uint8_t web client
Hello, I am getting the result page, but I need this information in String. For use in other procedures.
Below the code commented in my need.
#include <UIPEthernet.h>
EthernetClient client;
signed long next;
  uint8_t mac[6] = {0x00,0x01,0x02,0x03,0x04,0x05};
  Ethernet.begin(mac);
  Serial.print("localIP: ");
  Serial.println(Ethernet.localIP());
  Serial.print("subnetMask: ");
  Serial.println(Ethernet.subnetMask());
  Serial.print("gatewayIP: ");
  Serial.println(Ethernet.gatewayIP());
  Serial.print("dnsServerIP: ");
  Serial.println(Ethernet.dnsServerIP());
  next = 0;
  if (((signed long)(millis() - next)) > 0)
      next = millis() + 5000;
      Serial.println("Client connect");
      // replace hostname with name of machine running tcpserver.pl
//      if (client.connect("server.local",5000))
      if (client.connect(IPAddress(192,168,0,1),5000))
          Serial.println("Client connected");
          client.println("DATA from Client");
          while(client.available()==0)
              if (next - millis() < 0)
                goto close;
          int size;
          while((size = client.available()) > 0)
              uint8_t* msg = (uint8_t*)malloc(size);
              size = client.read(msg,size);
              Serial.write(msg,size);    //  <<<<-------- I need this result in string
              free(msg);
close:
          //disconnect client
          Serial.println("Client disconnect");
          client.stop();
        Serial.println("Client connect failed");
You most certainly do NOT. Use strings (NULL terminated arrays of chars. If you have some function that insists it needs a String, delete it.
Adding time variables is not guaranteed to work. Subtraction is.
                goto close;
NEVER!. Deal with the opposite case, instead.
It would BE a string if you used the proper type (char) and added a NULL terminator. You have the number of characters, so you know where to put the NULL.
