uint8_t
Hi i have this problem , im new to arduino , how to fix it , please ?
Arduino: 1.0.6 (Windows 7), Board: "Arduino Uno"
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=106 -IC:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\variants\standard -IC:\Program Files (x86)\Arduino\libraries\Wire -IC:\Users\USER\Documents\Arduino\libraries\LiquidCrystal_I2C C:\Users\USER\AppData\Local\Temp\build3012311874335267102.tmp\HelloWorld.cpp -o C:\Users\USER\AppData\Local\Temp\build3012311874335267102.tmp\HelloWorld.cpp.o
In file included from HelloWorld.pde:2:
C:\Users\USER\Documents\Arduino\libraries\LiquidCrystal_I2C/LiquidCrystal_I2C.h:80: error: conflicting return type specified for 'virtual void LiquidCrystal_I2C::write(uint8_t)'
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/Print.h:48: error: overriding 'virtual size_t Print::write(uint8_t)'
You've shown us your problem, but not the cause of the problem.
Are you using this library? http://hmario.home.xs4all.nl/arduino/LiquidCrystal_I2C/
If so, you have the old version and you should update to the latest version.
The LiquidCrystal_I2C class implements the write() method that the class that it derives from (at least indirectly) has declared as a virtual function. The signature in the Print class says that the function, when implemented properly, will return a size_t type value. The implementation in the LiquidCrystal_I2C class is incorrect, in that it says that it will return nothing.
You can change the declaration in the LiquidCrystal_I2C.h file, and the implementation in the LiquidCrystal_I2C.cpp file (and make the function actually return something), or you can find a newer version where that has already been done.
Your library is pre-Arduino 1.0, yet you are compiling it on 1.0.6
thanks for the help but i downloaded the latest arduino version and still not working
And what version is the library?
how to know which version it is ? and how i can download the new one ?pleae...
Does it matter? It doesn't compile, which means that the version you have is not compatible with the version of the IDE you are using.
Click the here link in oqibidipo's reply.
khalidshahbari:
Open source has many random authors. You have to do a web search.
