UINT_MAX was not declared
Hi all,
I'm just trying to work with this sketch to control wind speed from an anemometer. Everything works, but when I want to knot the gust (or the highest wind speed of the measuring period) I received an error:'UINT_MAX' was not declared in this scope. The error comes from the last line of the code
Anybody could help me to understand and fix the problem?
Thank's
Eduard
#include <math.h>
//Variable to setup the machine ON
unsigned long vtime; //Declara un variable del mismo tipo que la que devuelve micros()
// Each time we loop through the main loop, we check to see if it's time to capture the sensor readings
unsigned int sensorCapturePeriod = 100;
unsigned int vtimeNextSensorReading;
  initializeAnemometer();
  // Schedule the next sensor reading and publish events
  vtimeNextSensorReading = millis() + sensorCapturePeriod;
  vtime = millis();
  // Capture any sensors that need to be polled
  // The wind speed sensors use interrupts, and so data is collected "in the background"
  if (vtimeNextSensorReading <= millis()) {
  // Publish the data collected
  float gustKPH;
  float windKPH = (getAndResetAnemometerkph(&gustKPH));
  float knots = windKPH * 0.5399;
  //print data
  String SPKwind = String(windKPH);
  String SPKgust = String(gustKPH);
  String SPKknots = String(knots);
  Serial.print("WindKPH");
  Serial.println(SPKwind);
  delay(10);
// Wind Speed (Anemometer)
int AnemometerPin = 5;
float AnemometerScalekph = 1.492; // Windspeed if we got a pulse every second (i.e. 1Hz)
volatile unsigned int AnemoneterPeriodTotal = 0;
volatile unsigned int AnemoneterPeriodReadingCount = 0;
volatile unsigned int GustPeriod = UINT_MAX;
unsigned int lastAnemoneterEvent = 0;
void initializeAnemometer() {
  pinMode(AnemometerPin, INPUT_PULLUP);
  GustPeriod = UINT_MAX;  //  The shortest period (and therefore fastest gust) observed
  attachInterrupt(AnemometerPin, handleAnemometerEvent, FALLING);
  return;
void handleAnemometerEvent() {
  // Activated by the magnet in the anemometer (2 ticks per rotation), attached to input D3
  unsigned int vtimeAnemometerEvent = millis(); // grab current time
  //If there's never been an event before (first time through), then just capture it
  if (lastAnemoneterEvent != 0) {
    // Calculate time since last event
    unsigned int period = vtimeAnemometerEvent - lastAnemoneterEvent;
    // ignore switch-bounce glitches less than 10mS after initial edge (which implies a max windspeed of 149kph)
    if (period < 10) {
      return;
    //       if(period < GustPeriod) {
    //            // If the period is the shortest (and therefore fastest windspeed) seen, capture it
    //            GustPeriod = period;
    AnemoneterPeriodTotal += period;
    AnemoneterPeriodReadingCount++;
  lastAnemoneterEvent = vtimeAnemometerEvent; // set up for next event
float getAndResetAnemometerkph(float * gustKPH)
  if (AnemoneterPeriodReadingCount == 0)
    *gustKPH = 0.0;
    return 0;
  float result = AnemometerScalekph * 1000.0 * float(AnemoneterPeriodReadingCount) / float(AnemoneterPeriodTotal);
  *gustKPH = AnemometerScalekph  * 1000.0 / float(GustPeriod);
  return result;
Well, you need to define UINT_MAX before you can use it. Try to add
#include <math.h>
#define UINT_MAX 65535
Hi
soooo stupid from me!!
thank's
First something different:
This will go wrong when millis() rolls over. ALWAYS check time in the way:
millis() - lastMillis >= interval
That way the roll over has no consequence.
[edit]To slowwwwwwwwww :p[/edit]
But to the problem, for which device do you try to compile? And where do you think INT_MAX should be defined?
I think you need to include limits.h or climits.
arduino_new:
Or
#define UINT_MAX ((unsigned int)~0)
But yeah - better to include limits.h (if that's the correct one).
