UIPEthernet.h with Atmel Mighty 1284p
Greetings everybody,
I'm having a hard time using UIPEthernet.h with an Atmel Mighty 1284p MCU.
I'm using the latest UIPEthernet library (ver. 2.0.6), downloaded through Arduino IDE (ver 1.8.10.0)
The ethernet chip is Enc28J60, and I added this section into UIPEthernet\utility\Enc28J60Network.h:
#if defined(__AVR_ATmega1284P__)
  #define SPI_MOSI 5
  #define SPI_MISO 6
  #define SPI_SCK  7
  #define SPI_CS   4
#endif
But the call to Ethernet.begin(macAddress) fails every single time (it takes 15-20 seconds, and then it returns 0).
What else am I missing? Any help is greatly appreciated.
Thanks a lot.
Bogdan.
Please post your complete Enc28J60Network.h file here in code tags.
Which board do you have selected from the Tools > Board menu?
Greetings and thanks.
THis is the board: “maniacbug” Mighty 1284p 16MHz using Optiboot.
The file Enc28J60Network.h is too large to post in one message, so I’m posting it in two parts. This is part one:
 Enc28J60NetworkClass.h
 UIPEthernet network driver for Microchip ENC28J60 Ethernet Interface.
 Copyright (c) 2013 Norbert Truchsess <norbert.truchsess@t-online.de>
 All rights reserved.
 inspired by enc28j60.c file from the AVRlib library by Pascal Stang.
 For AVRlib See http://www.procyonengineering.com/
 This program is free software: you can redistribute it and/or modify
 it under the terms of the GNU General Public License as published by
 the Free Software Foundation, either version 3 of the License, or
 (at your option) any later version.
 This program is distributed in the hope that it will be useful,
 but WITHOUT ANY WARRANTY; without even the implied warranty of
 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 GNU General Public License for more details.
 You should have received a copy of the GNU General Public License
 along with this program.  If not, see <http://www.gnu.org/licenses/>.
#ifndef Enc28J60Network_H_
#define Enc28J60Network_H_
#include "mempool.h"
#if defined(__MBED__)
  #include <mbed.h>
  //UIPEthernet(SPI_MOSI, SPI_MISO, SPI_SCK, SPI_CS);
  #if defined(TARGET_LPC1768)
    #define SPI_MOSI p11
    #define SPI_MISO p12
    #define SPI_SCK  p13
    #define SPI_CS   p8
  #elif defined(TARGET_LPC1114)
    #define SPI_MOSI dp2
    #define SPI_MISO dp1
    #define SPI_SCK  dp6
    #define SPI_CS   dp25
  #elif defined(TARGET_LPC11U68)
    #define SPI_MOSI P0_9
    #define SPI_MISO P0_8
    #define SPI_SCK  P1_29
    #define SPI_CS   P0_2
  #elif defined(TARGET_NUCLEO_F103RB) || defined(TARGET_NUCLEO_L152RE) || defined(TARGET_NUCLEO_F030R8)  \
    || defined(TARGET_NUCLEO_F401RE) || defined(TARGET_NUCLEO_F302R8) || defined(TARGET_NUCLEO_L053R8)  \
    || defined(TARGET_NUCLEO_F411RE) || defined(TARGET_NUCLEO_F334R8) || defined(TARGET_NUCLEO_F072RB)  \
    || defined(TARGET_NUCLEO_F091RC) || defined(TARGET_NUCLEO_F303RE) || defined(TARGET_NUCLEO_F070RB)
    #define SPI_MOSI D4
    #define SPI_MISO D5
    #define SPI_SCK  D3
    #define SPI_CS   D2
  #elif defined(__AVR_ATmega1284P__)
    #define SPI_MOSI 5
    #define SPI_MISO 6
    #define SPI_SCK  7
    #define SPI_CS   4
  #endif
  #define ENC28J60_CONTROL_CS SPI_CS
#endif
#if defined(STM32F3) || defined(STM32F2)                //This is workaround for stm32duino STM32F2, and adafruit wiced feather STM32F2
  #define BOARD_SPI1_NSS_PIN        PA4
  #define BOARD_SPI1_SCK_PIN        PA5
  #define BOARD_SPI1_MISO_PIN       PA6
  #define BOARD_SPI1_MOSI_PIN       PA7
#endif                              			//This is workaround for stm32duino STM32F3, and adafruit wiced feather STM32F2
#if defined(BOARD_discovery_f4)
  #define __STM32F4__
#endif
#if defined(__MK20DX128__) || defined(__MKL26Z64__)
  #include <SPIFIFO.h>
#endif
#if !defined(ENC28J60_CONTROL_CS)
   #if defined(__AVR__) || defined(ESP8266) || defined(__RFduino__)
      // Arduino Uno (__AVR__) SS defined to pin 10
      // Arduino Mega(__AVR_ATmega2560__) SS defined to pin 53
      // ESP8266 (ESP8266) SS defined to pin 15
      #define ENC28J60_CONTROL_CS     SS
   #elif defined(ARDUINO_ARCH_AMEBA) //Defined SS to pin 10
      #define ENC28J60_CONTROL_CS     SS //PC_0 A5 10
   #elif defined(ARDUINO_ARCH_SAM)
      // Arduino Due (ARDUINO_ARCH_SAM) BOARD_SPI_DEFAULT_SS (SS3) defined to pin 78
      //#define ENC28J60_CONTROL_CS     BOARD_SPI_DEFAULT_SS
      #define ENC28J60_CONTROL_CS     BOARD_SPI_SS0
   #elif defined(ARDUINO_ARCH_SAMD)
   #elif defined(__ARDUINO_ARC__) //Intel ARC32 Genuino 101
   #elif defined(__RFduino__) //RFduino
   #elif defined(ARDUINO_ARCH_STM32) // STM32duino core
   #elif defined(ARDUINO_ARCH_ESP32) // arduino-esp32
   #elif defined(STM32_MCU_SERIES) || defined(__STM32F1__) || defined(__STM32F3__) || defined(STM32F3) || defined(__STM32F4__) || defined(STM32F2)
      #if defined(BOARD_SPI1_NSS_PIN)
         #define ENC28J60_CONTROL_CS     BOARD_SPI1_NSS_PIN
      #elif defined(ARDUINO_STM32F4_NETDUINO2PLUS)
         #define ENC28J60_CONTROL_CS     PC8
      #else
         #define ENC28J60_CONTROL_CS     SPI.nssPin()
         //#define ENC28J60_CONTROL_CS     PA4
      #endif
   #elif defined(__MK20DX128__) || defined(__MKL26Z64__) || defined(__MK20DX256__) || defined(__MK64FX512__) || defined(__MK66FX1M0__)
      #define ENC28J60_CONTROL_CS     PIN_SPI_SS
   #endif
   #if defined(ENC28J60_CONTROL_CS)
      #warning "Not defined ENC28J60_CONTROL_CS. Use borad default SS pin setting. You can configure in 'utility/Enc28J60Network.h'."
   #endif
#endif
   #error "Not defined ENC28J60_CONTROL_CS!"
#endif
#if !defined(SPI_MOSI)
      #define SPI_MOSI MOSI
      #define SPI_MOSI 11 //PC_2
   #elif defined(ARDUINO_ARCH_SAM) || defined(ARDUINO_ARCH_SAMD)
      #define SPI_MOSI PIN_SPI_MOSI
      #if defined(BOARD_SPI1_MOSI_PIN)
         #define SPI_MOSI BOARD_SPI1_MOSI_PIN
      #else
         #define SPI_MOSI SPI.mosiPin()
      #endif
   #endif
#endif
   #error "Not defined SPI_MOSI!"
#endif
#if !defined(SPI_MISO)
      #define SPI_MISO MISO
      #define SPI_MISO 12 //PC_3
      #define SPI_MISO PIN_SPI_MISO
      #if defined(BOARD_SPI1_MISO_PIN)
         #define SPI_MISO BOARD_SPI1_MISO_PIN
      #else
         #define SPI_MISO SPI.misoPin()
      #endif
   #endif
#endif
   #error "Not defined SPI_MISO!"
#endif
#if !defined(SPI_SCK)
      #define SPI_SCK SCK
      #define SPI_SCK 13 //PC_1 A4
      #define SPI_SCK PIN_SPI_SCK
      #define SPI_SCK SCK
      #define SPI_SCK SCK
      #define SPI_SCK SCK
      #define SPI_SCK SCK
      #if defined(BOARD_SPI1_SCK_PIN)
         #define SPI_SCK BOARD_SPI1_SCK_PIN
      #else
         #define SPI_SCK SPI.sckPin()
      #endif
   #endif
#endif
   #error "Not defined SPI_SCK!"
#endif
  #define SPI_MOSI 5
  #define SPI_MISO 6
  #define SPI_SCK  7
  #define SPI_CS   4
#endif
And this is part two of Enc28J60Network.h:
#if defined(__MBED__) || defined(ARDUINO_ARCH_SAM) || defined(ARDUINO_ARCH_SAMD) || defined(__ARDUINO_ARC__) || defined(__STM32F1__) || defined(__STM32F3__) || defined(STM32F3) || defined(__STM32F4__) || defined(STM32F2) || defined(ESP8266) || defined(ARDUINO_ARCH_AMEBA) || defined(__MK20DX128__) || defined(__MKL26Z64__) || defined(__MK20DX256__) || defined(__MK64FX512__) || defined(__MK66FX1M0__) || defined(__RFduino__) || defined(ARDUINO_ARCH_STM32) || defined(ARDUINO_ARCH_ESP32)
   #if defined(ARDUINO) && defined(STM32F3)
      #include "HardwareSPI.h"
   #else
      #include <SPI.h>
   #endif
   #define ENC28J60_USE_SPILIB 1
#endif
#define UIP_RECEIVEBUFFERHANDLE 0xff
 * Empfangen von ip-header, arp etc...
 * wenn tcp/udp -> tcp/udp-callback -> assign new packet to connection
#define TX_COLLISION_RETRY_COUNT 10
class Enc28J60Network : public MemoryPool
private:
  static uint16_t nextPacketPtr;
  static uint8_t bank;
  static uint8_t erevid;
  static struct memblock receivePkt;
  static bool broadcast_enabled; //!< True if broadcasts enabled (used to allow temporary disable of broadcast for DHCP or other internal functions)
  static uint8_t readOp(uint8_t op, uint8_t address);
  static void writeOp(uint8_t op, uint8_t address, uint8_t data);
  static uint16_t setReadPtr(memhandle handle, memaddress position, uint16_t len);
  static void setERXRDPT(void);
  static void readBuffer(uint16_t len, uint8_t* data);
  static void writeBuffer(uint16_t len, uint8_t* data);
  static uint8_t readByte(uint16_t addr);
  static void writeByte(uint16_t addr, uint8_t data);
  static void setBank(uint8_t address);
  static uint8_t readReg(uint8_t address);
  static void writeReg(uint8_t address, uint8_t data);
  static void writeRegPair(uint8_t address, uint16_t data);
  static void phyWrite(uint8_t address, uint16_t data);
  static uint16_t phyRead(uint8_t address);
  static void clkout(uint8_t clk);
  static void enableBroadcast (bool temporary);
  static void disableBroadcast (bool temporary);
  static void enableMulticast (void);
  static void disableMulticast (void);
  static uint8_t readRegByte (uint8_t address);
  static void writeRegByte (uint8_t address, uint8_t data);
  friend void enc28J60_mempool_block_move_callback(memaddress,memaddress,memaddress);
public:
  void powerOn(void);
  void powerOff(void);
  static uint8_t geterevid(void);
  uint16_t PhyStatus(void);
  static bool linkStatus(void);
  static void init(uint8_t* macaddr);
  static memhandle receivePacket(void);
  static void freePacket(void);
  static memaddress blockSize(memhandle handle);
  static void sendPacket(memhandle handle);
  static uint16_t readPacket(memhandle handle, memaddress position, uint8_t* buffer, uint16_t len);
  static uint16_t writePacket(memhandle handle, memaddress position, uint8_t* buffer, uint16_t len);
  static void copyPacket(memhandle dest, memaddress dest_pos, memhandle src, memaddress src_pos, uint16_t len);
  static uint16_t chksum(uint16_t sum, memhandle handle, memaddress pos, uint16_t len);
extern Enc28J60Network Enc28J60;
#endif /* Enc28J60NetworkClass_H_ */
I don’t see any problems with your modifications to the library code. Make sure your wiring matches this pinout:
//           (D 0) PB0  1|        |40  PA0 (AI 0 / D24)
//           (D 1) PB1  2|        |39  PA1 (AI 1 / D25)
//      INT2 (D 2) PB2  3|        |38  PA2 (AI 2 / D26)
//       PWM (D 3) PB3  4|        |37  PA3 (AI 3 / D27)
//    PWM/SS (D 4) PB4  5|        |36  PA4 (AI 4 / D28)
//      MOSI (D 5) PB5  6|        |35  PA5 (AI 5 / D29)
//  PWM/MISO (D 6) PB6  7|        |34  PA6 (AI 6 / D30)
//   PWM/SCK (D 7) PB7  8|        |33  PA7 (AI 7 / D31)
//                 RST  9|        |32  AREF
//                 VCC 10|        |31  GND
//                 GND 11|        |30  AVCC
//               XTAL2 12|        |29  PC7 (D 23)
//               XTAL1 13|        |28  PC6 (D 22)
//      RX0 (D 8)  PD0 14|        |27  PC5 (D 21) TDI
//      TX0 (D 9)  PD1 15|        |26  PC4 (D 20) TDO
// RX1/INT0 (D 10) PD2 16|        |25  PC3 (D 19) TMS
// TX1/INT1 (D 11) PD3 17|        |24  PC2 (D 18) TCK
//      PWM (D 12) PD4 18|        |23  PC1 (D 17) SDA
//      PWM (D 13) PD5 19|        |22  PC0 (D 16) SCL
//      PWM (D 14) PD6 20|        |21  PD7 (D 15) PWM
The numbers in parentheses are the Arduino pin numbers
