UIPethernet TCP persistent server with two way communication
Hi Guys,
I am very new to Arduino, so please be patient. I was trying to run TCP server using UIPethernet library on Arduino Mega 2560 +Enc28J60. The problem I am having is after few hours or sometimes few minutes the server stopped working and the client complain about the socket connection.
So I tried the example given with the UIPEthernet library.
#include <SPI.h>
#include <UIPEthernet.h>
EthernetServer server = EthernetServer(1000);
  uint8_t mac[6] = {0x00,0x01,0x02,0x03,0x04,0x05};
  IPAddress myIP(172,16,12,149);
  Ethernet.begin(mac,myIP);
  server.begin();
  size_t size;
  if (EthernetClient client = server.available())
      while((size = client.available()) > 0)
          uint8_t* msg = (uint8_t*)malloc(size);
          size = client.read(msg,size);
          Serial.write(msg,size);
          client.write(msg,size);
          free(msg);
      client.println("DATA from Server!");
      client.stop();
the only addition I did was " client.write(msg,size); " to make it kind of echo server. I used my python script to connect to server.
import select
import socket
import time
import sys
def make_connection(ip='172.16.12.149'):
    TCP_IP = ip
    TCP_PORT = 1000
    BUFFER_SIZE = 1024
    try:
        s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
        s.settimeout(5)
        s.connect((TCP_IP, TCP_PORT))
    except:
        sys.stdout.write("error: socket connection failed")
        return False,False
    return True,s
state,s = make_connection()
while (1):
    try:
        s.send("Remember My name!! walter\n")
        lines = s.recv(4096)
    except:
        print " Walter W... died"
        sys.exit(1)
    print lines
    time.sleep(.2)
    s.close()
The script is making connection every 0.2 sec approx and sending a sentence and reading the same sentence back. What happen is after some time, the python script complain about the socket connection or it receive nothing back. If I try to connect it again, the socket connection won’t connect. hence I need to power-cycle the Arduino in order to get it running. I have been playing around with different options but nothing working for me. I also tried the echoserver example with no success. The interesting thing is when I don’t echo anything back from the TCP_server, It seems to work for ages. I hope I am clear in explaining my problem. thanks
I have added "client.flush()" on the server side before closing the connection using client.stop(). Things are looking little better. The server has been running for 1-hour and counting....
so its has been working since...
