UIPEthernet warnings
Hi, when I compile my code i get two warnings:
......\Arduino\libraries\UIPEthernet\utility\uipopt.h:97:4: warning: #warning "Endianness configured automaticaly." [-Wcpp]
.......\Arduino\libraries\UIPEthernet\utility\logging.h:24:2: warning: #warning "You can configure LogObject and ACTLOGLEVEL in 'utility/logging.h'. More verbosity more memory usage." [-Wcpp]
I've tried to write above and below:
#define ACTLOGLEVEL LOG_NONE
but it doesn't work. Do you know how to solve it?
post your code using code tags </> and the complete error messages
what arduino board are you using and what Ethernet shield?
if it is a new project, please use the EthernetENC library.
(I maintain both libraries)
#define IR_SEND_PIN 3
#include <IRremote.hpp>
#include <UIPEthernet.h>
#define ACTLOGLEVEL LOG_NONE  // <- This may be a solution but it doesn't work
static uint8_t mac[6] = {0x54, 0x55, 0x58, 0x10, 0x00, 0x24};
IPAddress ip(192, 168, 0, 200);
EthernetServer server = EthernetServer(80);
  IrSender.begin();
  Ethernet.begin(mac, ip);
  server.begin();
  if (client) {
    boolean currentLineIsBlank = true;
    String buffer = "";
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        buffer += c;
        if (c == '\n' && currentLineIsBlank) {
          client.println("HTTP/1.1 200 OK"); // HTTP response
          client.println("Content-Type: text/html");
          client.println();
        if (c == '\n') {
          buffer = "";
        else if (c == '\r') {
          if (buffer.indexOf("GET /?code=") >= 0) { //http://192.168.0.200/?code=123456
            String s = buffer.substring(11, 17);
            //uint32_t code = 0xFF02FD;
            uint32_t code = 0;
            for (int i = 0; i < s.length(); ++i) {
              if (s[i] >= '0' and s[i] <= '9') {
                code *= 16;
                code += s[i] - '0';
              } else if (s[i] == 'a' or s[i] == 'A') {
                code *= 16;
                code += 10;
              } else if (s[i] == 'b' or s[i] == 'B') {
                code *= 16;
                code += 11;
              } else if (s[i] == 'c' or s[i] == 'C') {
                code *= 16;
                code += 12;
              } else if (s[i] == 'd' or s[i] == 'D') {
                code *= 16;
                code += 13;
              } else if (s[i] == 'e' or s[i] == 'E') {
                code *= 16;
                code += 14;
              } else if (s[i] == 'f' or s[i] == 'F') {
                code *= 16;
                code += 15;
            //Serial.println(code);
            //ON-OFF code 0xFF02FD
            //code = 0xFF02FD;
            IrSender.sendNECMSB(code, uint8_t(32)); //https://github.com/Arduino-IRremote/Arduino-IRremote
        else {
          currentLineIsBlank = false;
    client.stop(); // End server
Arduino model: Arduino Nano
Ethernet Shield: ENC28J60
I am having some issues with arduino memory space. Do you thing changing to EthernetENC will help to solve this?
I will change it anyway but for asking.
https://github.com/JAndrassy/EthernetENC/wiki/Settings
this applies to both libraries
