UK help needed
Hi all, I'm looking for someone to build a little device for me here in the UK. The device I want making needs to monitor the output from a pair of loadcells or strain gauges, record the results & then download/transmit them to a laptop for graphing in a simple spreadsheet. Sounds like it shouldn't be difficult but I have absolutely no idea so need someone to do this for me. Any takers for a bit of paid work? Look forward to hearing from you. Jon
Really, nobody? Can't believe what I'm asking for is technically difficult. Anyone care to comment?
I have no idea why there are no replies. In case it's because your topic is in the wrong section I'll move to a more appropriate place.
Unless you put the topic here deliberately. Does the person have to be in the UK? Is that why this topic is in Local Groups?
Coding Badly, thanks for your help and please move this post to where ever you think is most appropriate. Does the builder need to be in the UK? mmmm well it would certainly make discussions & posting things back & forth easier but I suppose in principle no it doesn't really matter. Jon
PM sent. I'm in the UK.
jonsaddles: The device I want making needs to monitor the output from a pair of loadcells or strain gauges,
Have you selected an instrumentation amplifier or will you need help with that? In other words, is it a programming only or programming and electronic design?
record the results
How much data? Timestamped? To a removable SD card? Or is the device to be completely self contained?
Permanent storage is spreadsheet? Database? Text file?
Spreadsheet you made? The contractor is expected to make?
Excel? The Google spreadsheet application?
How? Email? Personal Message? Forum post?
[quote author=Coding Badly link=topic=107034.msg806167#msg806167 date=1337974161]Have you selected an instrumentation amplifier or will you need help with that? In other words, is it a programming only or programming and electronic design?[/quote]
Yes def need help with that it is a turn key project
Aprox 10mins worth of data and yes timestamped. Self contained device I can then plugin to the usb port on my laptop
Yes I will be importing the data into a Open Office Spreadsheet
Either is OK
How? Email? Personal Message? Forum post?.
Via pm on here please
Thanks for your time & assistance, there are probably plenty of other questions so please feel free to ask. Cheers Jon
