Has anyone got a link to a decent UK motor + gearbox supplier?
I need 12/24v 200RPM motor with gearbox of reasonably decent quality to drive a large mechanical screw.
I found this...
But AS I TOTALLY HATE .... even though the website is .co.uk, it ships from China.
I am getting caught out with that trick more and more.
You can spin the auger by hand as it's on some decent bearings. It just lifts a golf ball, so literally no 'load'. Just the weight of the mech itself.
Wipers motors are OK, but might be a bit slow (unless I gear them up).
Yea the keyway is an easy fix
The centre shaft on the block bearings is a 25mm shaft. Then they have made the auger sit on this centre 25mm shaft using another set of bearings, so the whole mech is actually running on two sets of bearings.
So, my plan was to make a 3d printed, solid 'clamp' that fits to the top of the auger shaft piece with embedded Neodymium magnets.
Then a matching piece that clamps to the 25mm shaft above it.
I am driving the 25mm shaft with my chain. So this would give me a 'clutch'
