Hey. I need help with my code. Are stepping sequences and code good or should I change anything? So my question is how do I get best torque from 5v, 28byj-48 motor? Speed is not important to me. Thanks for your help!
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int val;
int lightbulb = 7;
int sec = 50;
int min = 59;
int i=0;
#define A 8
#define B 9
#define C 10
#define D 13
#define NUMBER_OF_STEPS_PER_REV 2048
// #include <Adafruit_Sensor.h> // POIZKUSI BREZ
#include <DHT.h>
#define DHTPIN 6
#define DHTTYPE DHT22 // DHT 22 (AM2302)
DHT dht = DHT(DHTPIN, DHTTYPE);
byte tem[8] = //thermometer
B00100,
B01010,
B01010,
B01110,
B01110,
B11111,
B11111,
B01110
byte drop[8] = //droplet
B00100,
B00100,
B01010,
B01010,
B10001,
B10001,
B10001,
B01110,
byte bulb[8] = //light bulb
B01110,
B10001,
B10001,
B10001,
B01110,
B01110,
B01110,
B00000
byte degree[8] = //degree
B01100,
B10010,
B10010,
B01100,
B00000,
B00000,
B00000,
B00000
byte Motor[8] = //motor
B00010,
B11111,
B00010,
B00000,
B10001,
B11011,
B10101,
B10001
dht.begin();
lcd.begin(16,2);
lcd.createChar(1,tem);
lcd.createChar(2,drop);
lcd.createChar(3,bulb);
lcd.createChar(4,degree);
lcd.createChar(5,Motor);
pinMode(A,OUTPUT);
pinMode(B,OUTPUT);
pinMode(C,OUTPUT);
pinMode(D,OUTPUT);
delay(2000);
void write(int a,int b,int c,int d){
digitalWrite(A,a);
digitalWrite(B,b);
digitalWrite(C,c);
digitalWrite(D,d);
void onestep(){
write(1,1,0,0);
delay(2);
write(0,1,0,0);
delay(2);
write(0,1,1,0);
delay(2);
write(0,0,1,0);
delay(2);
write(0,0,1,1);
delay(2);
write(0,0,0,1);
delay(2);
write(1,0,0,1);
delay(2);
write(1,0,0,0);
// Read the humidity in %:
float h = dht.readHumidity();
// Read the temperature as Celsius:
float t = dht.readTemperature();
// Check if any reads failed and exit early (to try again):
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from DHT sensor!");
return;
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" % ");
Serial.print("Temperature: ");
Serial.print(t);
Serial.print(" \xC2\xB0");
Serial.println("C | ");
lcd.setCursor(2,0);
lcd.print(t);
lcd.write(4);
lcd.print("C");
lcd.print(" ");
lcd.setCursor(0,0);
lcd.write(1);
lcd.setCursor(2,1);
lcd.print(h);
lcd.print("%");
lcd.print(" ");
lcd.setCursor(0,1);
lcd.write(2);
if(t<37.5){
analogWrite(lightbulb,0);
lcd.setCursor(15,0);
lcd.write(3);}
if(t>38.5){
analogWrite(lightbulb,255);
lcd.print(" ");
sec=sec+1;
delay (825);
lcd.setCursor(11,1);
if(min<10)lcd.print("0");
lcd.print(min);
lcd.print(":");
if(sec<10)lcd.print("0");
lcd.print(sec);
if(sec>58){
sec=-1;
min=min+1;
if(min>59){
lcd.print("00:00");
lcd.setCursor(13,0);
lcd.write(5);
delay(10);
while(i<NUMBER_OF_STEPS_PER_REV){
onestep();
i++;
if(min>59){
min=0;}
if(i=2048){ i=0;}
lcd.print(" ");
