ULN2003A alternative
Hallo
I recently did a project where I used some ULN200A darlington drivers to control LED stripes.
This worked well. I now made some changes to the projects and the LED stripes got a little longer. That leads to the Problem that I'm now slightly over 500mA.
So I'm looking for an alternative that if possible would fit where the ULN2003A was.
Any ideas?
I read in the data sheet of the LED stripe which currently run @ 24VDC that they support up to 25VDC. If I change that to 25, would it bring down the mA?
Why not just wire two ULN2003 in parallel. That way you can run 1000mA per strip.
It sounds like you need the ability to expand that to higher current. It's not as simple but a current limiter that can provide high current might be what you need.
You can build 8 of these circuits on a copper clad protoboard.
If you go through to step 9 you'll find the one using a high power mosfet with PWM / DC input.
You should make and attach some heat sinks to the mosfets, they're easy to make. Then put it all in a box.
The mosfet is a logic level input device so it can also work as a switch for silly levels of current. With a proper heatsink it can handle huge amounts of current, up to 54amps. :wink:
http://www.fairchildsemi.com/ds/FQ/FQP50N06L.pdf
In parallel! Thats a great idea. 1000mA is more then enough.
So I can just solder one on top of the other and use the same socket.
thx
