Indeed, this chip is really just a bunch of darlington transistors, no power pin is needed,
the emitters are commoned and this is usually connected to ground, the bases and collectors
are all separate pins (the bases have a resistor network to simplify drive requirements).
The remaining pin connects to the cathodes of 8 diodes whose anodes are each
connected to one of the darlington collectors - purely to facilitate switching inductive
loads like relays which would otherwise need a discrete flyback diode each.
mirith:
Oh, Hmm, I did not realize that the Com pin on these wasn't necessary. Are there any situation where you would not want to connect the Com to VCC?
When the diodes aren't needed and VCC is a long way away?
