ulta sonic data login
i have an ultra sonic sensor and i would like it if it would log the data in a micro sd card. I just got an ethernet shield with the micro sd card slot and im trying to have it put the data on there but when ever i put this line of code in:
File dataFile = SD.open("datalog.txt", FILE_WRITE);
the ultra sonic sensor stops blinking. The code uploads fine, but when i open the serial monitor nothing comes up.
I'm also including the sd.h library and i have been looking at the data logger example
thanks for all the help
will
some other wise mysterious code that I don't show you
Well, the solution is pretty obvious.
so how could i get it to log data and still use the ultra sonic sensor?
Well, we could all play twenty questions, or you could post your code.
Your choice.
Your choice.
Only partially, OP. Many of us are tired of that game.
