ultra sonic hc-sr04 sensor to trigger dfplayer
Hello,
I’m trying to use an ultra sonic hc-sr04 sensor to trigger a dfplayer in order to play a song.
My problem is that once it has been triggered and the song has finished I can not get the sensor to trigger the dfplayer again.
Does anyone know what I might need to change or include in the code?
This is the code I have been using:
#include "Arduino.h"
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
const byte SENSOR_COUNT = 1;
byte triggerPins[SENSOR_COUNT] = {9};
byte echoPins[SENSOR_COUNT]    = {13};
SoftwareSerial mySoftwareSerial(10, 11); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
  mySoftwareSerial.begin(9600);
  for( byte i=0; i<SENSOR_COUNT; i++ )
    pinMode(triggerPins[i], OUTPUT);
    pinMode(echoPins[i], INPUT);
  Serial.println(F("DFRobot DFPlayer Mini Demo"));
  Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
  if (!myDFPlayer.begin(mySoftwareSerial)) {  //Use softwareSerial to communicate with mp3.
    Serial.println(F("Unable to begin:"));
    Serial.println(F("1.Please recheck the connection!"));
    Serial.println(F("2.Please insert the SD card!"));
    while(true);
  Serial.println(F("DFPlayer Mini online."));
  myDFPlayer.volume(20);  //Set volume value. From 0 to 30
int currentSound = -1;
  for( byte i=0; i<SENSOR_COUNT; i++ ) // loop through all distance sensors
    if( detectPresence(i) ) // check if there is an object near it
      if(currentSound!=i) // check that it's a different sensor than the one that was last triggered
        Serial.print("play song number ");
        Serial.println(i);
        myDFPlayer.play(1); // play song nr `i+1`
      currentSound = i;
  if (myDFPlayer.available()) {
    printDetail(myDFPlayer.readType(), myDFPlayer.read()); //Print the detail message from DFPlayer to handle different errors and states.
// detectPresence will return TRUE if there is an object close to it.
bool detectPresence(byte sensorNr)
  if( sensorNr>=SENSOR_COUNT )
    return false;
  long duration, distance;
  //digitalWrite(triggerPins[sensorNr], LOW);  // Added this line
  //delayMicroseconds(10); // Added this line
  digitalWrite(triggerPins[sensorNr], HIGH);
  delayMicroseconds(15); // Added this line
  duration = pulseIn(echoPins[sensorNr], HIGH);
  distance = duration/58;
 return (distance > 1 && distance <= 8); { //distance in centimeter, fx between 1 - 8 cm
void printDetail(uint8_t type, int value){
  switch (type) {
    case TimeOut:
      Serial.println(F("Time Out!"));
    case WrongStack:
      Serial.println(F("Stack Wrong!"));
    case DFPlayerCardInserted:
      Serial.println(F("Card Inserted!"));
    case DFPlayerCardRemoved:
      Serial.println(F("Card Removed!"));
    case DFPlayerCardOnline:
      Serial.println(F("Card Online!"));
    case DFPlayerPlayFinished:
      Serial.print(F("Number:"));
      Serial.print(value);
      Serial.println(F(" Play Finished!"));
    case DFPlayerError:
      Serial.print(F("DFPlayerError:"));
      switch (value) {
        case Busy:
          Serial.println(F("Card not found"));
        case Sleeping:
          Serial.println(F("Sleeping"));
        case SerialWrongStack:
          Serial.println(F("Get Wrong Stack"));
        case CheckSumNotMatch:
          Serial.println(F("Check Sum Not Match"));
        case FileIndexOut:
          Serial.println(F("File Index Out of Bound"));
        case FileMismatch:
          Serial.println(F("Cannot Find File"));
        case Advertise:
          Serial.println(F("In Advertise"));
        default:
    default:
What do your debug prints say?
it says:
play song number 0
Number:1 Play Finished!
I just sorted it by changing the currentSound =i to currentSound = -1 in the for loop in the code.
It works now.
