Hi, everyone,
i am pretty fresh with programming and Arduino itself, so any positive critic is more than welcome. I am trying to assemble my first robot, which is using Pololu Zumo platform. I have two DC motors connected via DRV8833 . Also, i have an US-100 attached to a servo which is continuously scanning in front for obstacles. The problem is that there is some delay changing the path of the robot. Currently i have set 10cm limit distance, but there like 1-2 seconds before actually turning around after us-100 detects something.
Another issue that i have is that one of the motors is running at slower speed, currently i solved this one with another variable setting the speed for the 2nd motor a little bit lower, but i doubt it this is the right solution.
Again, this is my first "next-level" code, still trying to learn the basics. Any feedback will be appreciated.
#include <SoftwareSerial.h>;
#include <Servo.h>.
#include <DRV8833.h>
DRV8833 driver = DRV8833();
Servo myServo;
const int US100_TX = 2; //TX INPUT for Ultra-Sonic Sensor
const int US100_RX = 3; //RX INPUT for Ultra-Sonic Sensor
const int inputA1 = 6, inputA2 = 9, inputB1 = 11, inputB2 = 10; // Define DC motors OUTPUTS; PWN INPUTS
const int motorSpeedA = 130; //Define MotorA speed;
const int motorSpeedB = 100; //Define MotorB speed;
SoftwareSerial puertoUS100(US100_RX, US100_TX);
unsigned int MSByteDist = 0;
unsigned int LSByteDist = 0;
unsigned int mmDist = 0;
int temp = 0;
puertoUS100.begin(9600); //Define Ultra-Sonic Sensor
driver.attachMotorA(inputA1, inputA2); //Define MotorA Right
driver.attachMotorB(inputB1, inputB2); //Define MotorB Left
myServo.attach(4); //Define Servo motor
puertoUS100.flush();
puertoUS100.write(0x55);
if (puertoUS100.available() >= 2)
MSByteDist = puertoUS100.read();
LSByteDist = puertoUS100.read();
mmDist = MSByteDist * 256 + LSByteDist; //Distance calculation
if ((mmDist > 1) && (mmDist < 10000))
Serial.print("Distance: ");
Serial.print(mmDist, DEC);
Serial.println(" mm");
for (int i = -5; i > 120; i++) {
myServo.write(i);
delay(4);
for (int i = 120; i > -5; i--) {
myServo.write(i);
delay(4);
if (mmDist > 100){
driver.motorAForward(motorSpeedA);
driver.motorBForward(motorSpeedB);
if (mmDist < 100) {
driver.motorBStop();
