Ultra sonic sensor, direct in the USB/PC?
I would like to work with a ultra sonic sensor, but (if possible) I would like to connect it directly to the usb. Is there any distance sensor that I can connect directly to the PC??
Thanks.
The short answer is "no".I don't understand all the details, but if you have an Arduino board or similar, look for a surface-mounted chip on it (same side as the tracks). As I see it, this chip converts the Arduino protocols to the USB protocols, so you're going to need at least a similar chip, if not the Arduino itself. And you need to amplify the output from your sensor first. :stuck_out_tongue:
This sensor Ultrasonic Range Finder - LV-MaxSonar-EZ1 - SEN-00639 - SparkFun Electronics has a serial output that you may be able to connect to a PC using a serial to USB adapter. I say 'may' because the board (and rs-232 line) is powered from 5 volts. This is less than the normal rs-232 spec but the manufactures claim that it can drive PC serial ports. Download the datasheet and see if this could meet your needs.
its not USB though, but the Ultrasonic sensors from Maxbotix contain a demo software which you can download and in the PDF it explains how to directly connect it to your serial port, only GND and TX.
I have tested that when I got my sensor and it worked!
would be interesting how it works, I thought the sensors serial is TTL :o
Dan
Dan, the item linked in the post above yours is the Maxbotix sensor.
The sensor inverts the logic levels so it will work if the RS-232 port can cope with a signal that only goes from 0 to 5 volts (rs-232 usually is at least plus/minus 5 volts)
hi, yes, you must have posted while i was writing :wink:
I thougt 0volts doesnt mean anything to RS232 instead it is -3 (logic 1) to +3 (logic 0) Volts?! anyway, it worked for me...
Dan
Many PC interfaces implement rs-232 in a way that interprets any level above a few volts as positive, anything less as if it was negative. In fact, I think the original freeduino RS-232 boards worked that way.
That's not the way its supposed to be done, but it's a cheap shortcut that was popular in the days before the wide availability of the max232 chip. Still used by some to save a buck or two.
Thanks a lot for the replys!
