Ultra sonic Sensor not working correctly
Dear All, I am using Hagisonic HG40DAI sensor with Arduino uno. understand that the PIN 1. Trigger pin 2. Power -5v 3. Echo pin 4. Ground The data sheet is found her (http://www.robotshop.us/content/PDF/hagisonic-anibat-data-sheet.pdf).
Code
#define ECHOPIN  3 // Digital pin 3
#define TRIGPIN  2 // Digital pin 2
  // initialize serial communication:
  pinMode(ECHOPIN,INPUT);
  pinMode(TRIGPIN,OUTPUT);
    digitalWrite(TRIGPIN,LOW);
  delayMicroseconds(2);
  digitalWrite(TRIGPIN,HIGH);
   delayMicroseconds(10);
   distance =pulseIn(ECHOPIN,HIGH);
   Serial.print(distance); // Distance 1 just checking whether getting  correct distance  here
  distance = distance/58;
   Serial.print(distance);  //Distance 2
  Serial.print(" cm (Distance)");
  delay(200);
Getting distance 0.00cm at Distance 1 and Distance 2.
Any advise welcome. Appreciate your time and efforts :)
With thanks, Chandra
Read the data sheet. It suggests that the trigger pulse must be more than 2 milliseconds.
