Ultra Sonic sensor with glaileo
Hey guys i'm trying to get my ultra sonic sensor to work with my Galileo but i'm having trouble as the pulse-in function that aurdino offers doesn't work with the Galileo, i'm wondering does anyone know of an other way that i could use the ultrasonic sensor with the Galileo
There is a NewPing library that doesn't use pulseIn().
// Functions
//1.   Initisalise Variables
//  Parameter None
//  Result None
void SonarInit()
  int i;
     pinMode(TP,OUTPUT);
    pinMode(EP,INPUT);
    digitalWrite(TP,LOW);
  SonarActive = false;
  PCMSK0 |= 0b1100; // enable PC interrupts on arduino pins 50,51
void sendPing()
  SonarActive=true;
  digitalWrite(TP, HIGH);
  delayMicroseconds(10);
  PingS = micros();
  SonarTimeOut = 500;
  // Wemight get a false int here but check ib recieve time > minimum.
  PCICR  |= 1;  // enable PCI0 pin group interrupt
/// Pin-Change interrupt, for arduino pins 50..53, and 13..10
ISR(PCINT0_vect)
  unsigned long t = micros();
  int dt = t - PingS;
  if (dt > 470)
  // check which pin fell here, and note time
  // dt is the microsecond to 4 microsecond resolution of the path there and back.
  PCICR  &= 0xfe;  // disable PCI0 pin group interrupt
  UpdateAverage(dt);
   {  // still waiting for leading edge
  // showln ("here")
void ResetSonar()
//2.   Update Average array
//  Parameter new time count
//  Result None
void UpdateAverage (long Time)
   Avg[2]=Avg[1];
  Avg[1]=Time;
// faster to do this linear not loop
//3.   Calculate running average
//  Parameter None
//  Result New averag
long CalculateAvg()
  long total=0;
   total = (Avg[1]+Avg[2])/2;
   if (total <2830)
    return total;
  {   // max reliable count after range calcs are wrong..
          return(2830);
//4.  Calculate Distance
//  Parameter None
//  Result Distance cm
float CalculateDistance()
  float calcvalue;
  long avgtime = CalculateAvg();
   calcvalue = (avgtime /58.2);
   calcvalue = calcvalue / 2.0  ;
  // Distance_CM  = ((Duration of high level)*(Sonic :340m/s))/2
  showln(calcvalue);
  return calcvalue;
This code uses a single pin interrupt its set for mega pins but with a little research you should be able to modify…
Thank you very much ill give it a try .
