Clearly states 300Khz. You honestly think they would cap it for some strange reason at 20kHz? What do you think a High Pass filter is for?
Thanks for that answer. Excuse my ignorance. You are certainly justified in correcting my incorrect statement , although I'm not sure it is necessary to talk down to me . The purpose of this forum is not just to help you with your circuit. It is to help others learn. Thus when you post here you invite question and comments. It is up to you to decide how to respond to these. I don't think your reponse is really appropriate considering the question you were asking was:
Can you explain what the circuit does in a way that addresses Robin's point about the ultrasonic input and my point about the LM386 being an audio range (20 hz to 20khz ) amplifier ? Why does it have an audio amplifier on the output if the input is ultrasonic ? I
Your answer about the LM386 was right on (BW=300khz) , but I think you missed the fact that I got it backwards. The LM386 is actually on the INPUT and not the OUTPUT . I think an appropriate response would have been your comment about the BW
and a correction about where the LM386 was and what exactly it is doing, (meaning stage-1 has a gain of 200 and stage-2 has a gain of 20 for a total of 4000 and also that it is a High Pass filter. I'm not whining or being sensitive but was this really necessary ?
considering the question you were answering was this:
Can you explain what the circuit does ?
If I knew it was a high pass filter would I be asking you to explain the circuit ?
I think "The LM386 is a H/P filter with a two stage gain of 4000" would have sufficed. No matter where you go there is always going to be someone smarter than you. One would hope they don't rub it in. I'm just saying there's no need to be cocky.
The LM386N chips amplify the signals from the 40Khz sensitive transducer (40Khz is the most sensitive band of it) and passes it to the divider
As far as I can tell from page 2 of the datasheet, IC-1 is a Gain, of 200 and IC-2 is a Gain. of 20 for a total gain of 4000.
This is probably necessary due to the low amplitude of the bat signals or because of the diissipation of the amplitude over distance between the bat and the detector. Maybe it is a long-range bat detector. in any case the amplification needs to get the signal to a level that will clock the CMOS 7-stage Ripple-Carry Binary counter.
It is an ultrasonic to audio down converter as I stated here :
It looks like the 4024 is dividing the 40khz frequency by 16 (40khz/16=2.5khz) yielding a frequency audible by humans.
Can you confirm that ?
which is basically what you are saying here ;
The LM386N chips amplify the signals from the 40Khz sensitive transducer (40Khz is the most sensitive band of it) and passes it to the divider which will take the signal and divide the frequency by 16 to give a human audible ouput.
50KHz becomes around 3.1Khz (well within human range).
The difference being my estimation of the audio output frequency was a bit off (2.5khz vs 3.1 khz) because I used 40khz for my calculation instead of 50khz. (I'm not bat-savy)
