ultrasonic distance sensor reading distance of 0.00
I've been trying to make a rover that moves based on how far away it is from the wall, but I've run into this problem where my Ultrasonic Distance Sensor(HY-SRF05) keeps on reading a distance of 0.00
Here is my Code:
#define ECHO 5
#define TRIG 4
 pinMode(TRIG, OUTPUT);
 pinMode(ECHO, INPUT);
 digitalWrite(TRIG, LOW);
 delayMicroseconds(5);
 digitalWrite(TRIG, HIGH);
 delayMicroseconds(10);
 double echoIn = pulseIn(ECHO, HIGH);
 double distInCm = (echoIn/2.0) / 29.1;
 Serial.println(distInCm);
It’s worth pointing out that pulseIn returns an unsigned long, not a double, and anyway, on the AVRs, a double is the same as a float.
Please remember to use code tags when posting code.
You may want to check your wiring.
I refactored my code to use unsigned longs instead of floats, and my wiring is correct; my sensor might just be dead, I guess
try adding a timeout so
unsigned long echoIn = pulseIn(ECHO, HIGH,10000000ul);
