Ultrasonic HC-SR04 Activate Relay
Hi Guys, Need you help on solving a small issue i have… for now i manage to a HC-SR04 to on and off a relay.
What i want for my arduino to do is to on the relay when it measures a distance of 60-80cm. anything less the relay should be off. anything more the relay should be off as well.
#define echopin 9 // echo pin
#define trigpin 8 // Trigger pin
int maximumRange = 50;
long duration, distance;
Serial.begin (9600);
pinMode (trigpin, OUTPUT);
pinMode (echopin, INPUT );
pinMode (4, OUTPUT);
pinMode (13,OUTPUT);
void loop ()
digitalWrite(trigpin,LOW);
delayMicroseconds(2);
digitalWrite(trigpin,HIGH);
delayMicroseconds(10);
duration=pulseIn (echopin,HIGH);
distance= duration/58.2;
delay (50);
Serial.println(distance);
if (distance >= 25 ){
digitalWrite (13,HIGH);
else if (distance <=10) {
digitalWrite (13,LOW);
This was a code given to me by ibenkos… but and having difficulty to perform my programming… no errors but my relays keeps on active…
const int echopin = 9; // echo pin
const int trigpin = 8; // Trigger pin
const int maximumRange = 100;  // Maximum measured range in CM
long duration;
int distanceCM;
  // pinMode (4, OUTPUT);
  digitalWrite(trigpin, HIGH);
  digitalWrite(trigpin, LOW);
  duration = pulseIn (echopin, HIGH, maximumRange*60);
  distanceCM = duration/58.2;
  delay (50);
  Serial.println(distanceCM);
  // Turn on the output iff distance 60 to 80 cm inclusive.
  digitalWrite(13, distanceCM >= 60 && distanceCM <= 80);
Hi John...
Thank you... will try out the code and will update you if the circuit is running...
Devan
