Ultrasonic Sensor Actual Response Time
Hi, I'm working on the usual obstacle detection using HC-SR04. Basically, when an obstacle is detected, a vibration motor will switch on. Obstacle detection is just a part of my study. My professor requested me to measure the response time. Meaning, the time difference between detection of the hc-sr04, and the activation of the vibration motor. I know it's less than a second. Does anyone know a thing or two on how to do it? Thank you.
If you need anything like the code, photo, or whatsoever, just tell me. Thank you again.
You’ll find it is fast. Time is wasted in the delay between pings
#include <NewPing.h>
#define TRIGGER_PIN  12  // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN     11  // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
#define anypin 5 // your motorpin
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
  Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
  delay(50);   // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
  if (sonar.ping_cm()) // detect
  { long detect_time=micros(); // mark time
    // now trigger the motor
    digitalWrite(anypin,HIGH);
    long elapsed=micros()-detect_time;
    Serial.println(elapsed);
Thank you knut_ny. Since it is in microseconds, I guess I won't be able to measure it using any sort of actual or physical timer. Maybe I should settle with implementing it in code. I will try your suggestion. Thank you. :)
Worst case if an object appears @ 2m:
50ms delay in the code
send a ping (ca 20 microseconds)
sound travel time (330m/s) 4/330 => 12 ms
detection… microseconds
Sum: <63 ms
