Ultrasonic sensor and ledstrip color problem
So I've made a parking sensor with the Ultrasonic sensor and a ledstrip. But the ledstrip doesn't turn yellow or green. I think it has to do with the Thresholds. Can anyone help me to set this up? I also want a longer distance greater than 1 meter. This is my code:
#include "FastLED.h"
 #include <math.h>
    #define NUM_LEDS 32
    #define BRIGHTNESS 10
    #define DATA_PIN 4
    // Define the array of leds
    CRGB leds[NUM_LEDS];
    // Module Pins
    #define trigPin 11
    #define echoPin 12
    // Thresholds (in CM)
    long SECTION_SIZE = 80;
    long STOP_DISTANCE = 60;
    long WARNING_THRESHOLD = 50;
    long MAX_THRESHOLD = 375;
    long RED_THRESHOLD = STOP_DISTANCE;
    long YELLOW_THRESHOLD = RED_THRESHOLD + SECTION_SIZE;
    long GREEN_THRESHOLD = YELLOW_THRESHOLD + SECTION_SIZE;
    const int numReadings = 5;
    int readings[numReadings];      // the readings from the analog input
    int readIndex = 0;              // the index of the current reading
    int total = 0;                  // the running total
    int average = 0;                // the average
      Serial.begin (9600);
      FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
      FastLED.setBrightness(10);
      // HC-SR04 Setup
      pinMode(trigPin, OUTPUT);
      pinMode(echoPin, INPUT);
      // initialize all the readings to 0:
      for (int thisReading = 0; thisReading < numReadings; thisReading++) {
        readings[thisReading] = 0;
      long distance, lastRun;
      bool red, yellow, green;
      total = total - readings[readIndex];
      readings[readIndex] = calculateDistance();
      total = total + readings[readIndex];
      readIndex++;
      if (readIndex >= numReadings) readIndex = 0;
      distance = abs(total / numReadings);
      yellow = distance <= YELLOW_THRESHOLD && distance > RED_THRESHOLD;
      red = distance <= RED_THRESHOLD;
      green = distance > YELLOW_THRESHOLD && distance <= GREEN_THRESHOLD;
      if (red) {
        setRed();
      } else if (yellow) {
        setYellow(distance);
      } else if (green) {
        setGreen(distance);
        setGreenStandby();
      Serial.print(distance);
      Serial.println(" cm");
      FastLED.show();
      delay(1);
    void lightItUp(const CRGB& pColor, const CRGB& sColor, uint16_t travel) {
      uint16_t travelFix = travel * (NUM_LEDS/SECTION_SIZE);
      uint16_t leftStop = travelFix/2;
      uint16_t rightStop = NUM_LEDS - leftStop;
      for (int i = 0; i < NUM_LEDS; i++) {
        if (i < leftStop || i > rightStop) {
          leds[i] = pColor;
          leds[i] = sColor;
      FastLED.show();
    long calculateDistance() {
      long duration;
      digitalWrite(trigPin, LOW);
      delayMicroseconds(2);
      digitalWrite(trigPin, HIGH);
      delayMicroseconds(10);
      duration = pulseIn(echoPin, HIGH);
      return (duration/2) / 29.1;
    void setGreenStandby() {
      return fill_solid(leds, NUM_LEDS, CRGB::Black);
    void setRed() {
      return fill_solid(leds, NUM_LEDS, CRGB::Red);
    void setGreen(long distance) {
      long travel = GREEN_THRESHOLD - distance;
      return lightItUp(CRGB::Yellow, CRGB::Green, travel);
    void setYellow(long distance) {
      long travel = YELLOW_THRESHOLD - distance;
      return lightItUp(CRGB::Red, CRGB::Yellow, travel);
Did you check if the ultrasonic sensor works? What type is the ultrasonic sensor?
Did you check the LED functionality without the distance sensor?
Your caculateDistance function returns dm but the rest of the sketch looks more like you'e expect it to return cm.
