i use ultrasonic sensor arduino and atmega328p ,when i upload the arduino example ping code , the result will be normal,stable.but when i write my c code in atmel studio upload it, everything is fine except the distance stable,like this: 968,968...968, 138,968.....968,138. i don't know how it come out ? i just know after i send a pulse message and wait for the echo, the power will be low,high,low(for the distance 968) , i think the situation 138 is just high low, could anyone tell me why? thank you!
int getPulseWidth(int pingID) {
int timecount = 0;
int val = 0 ;
if(pingID == 7) {
val = PIND>>pingID; // Append signal value to val
while(val ==0) { // Loop until pin reads a high value
val = PIND>>pingID;
// USART_putint(val);
while(val == 1)
// USART_send('b');
val = PIND>>pingID;
++timecount; // Count echo pulse time
because i want detect the number of people who come through the door, so i don't need the accurate distance , i just set a distance , when someone come in or out the data will be small than the distance what i set. i'm sorry i forget to show all of the program , it should return timecount .
