I am trying to design a "gate" using an ultrasonic sensor and count the number of times an object it passed in front of the sensor. I am using a HC-SR94 and some WS2818B RGB Leds. The lights will start on red, and change colors as the counter is increased to a set number and then reset to red.
I will use the FastLED library as well as the ]asted code:
int trigPin = 4; //Define the pins that you will work with
int echoPin = 2;
int LEDR = 3;
int LEDV = 5;
float Speed = 0.0343; // Sound speed at cm/us
long duration, distance;
pinMode(trigPin, OUTPUT); //Define digital pin 7 as an output
pinMode(echoPin, INPUT); //Define digital pin 8 as an input
pinMode(LEDR, OUTPUT); //Define digital pin 10 as an output
pinMode(LEDV, OUTPUT); //Define digital pin 11 as an output
digitalWrite (LEDR , LOW); // Define digital pin 10 in a low status
digitalWrite (LEDV , LOW); //Define digital pin 11 in a low status
digitalWrite(trigPin, LOW); // Make sure that the TRIG is deactivated
delayMicroseconds(2); // Make sure that the TRIG is in LOW
digitalWrite(trigPin, HIGH); // Activate the output pulse
delayMicroseconds(10); // Wait for 10µs, the pulse remains active during this time
digitalWrite(trigPin, LOW); //Stop the pulse and wait for ECHO
duration = pulseIn(echoPin, HIGH) ; // pulseIn measures the time since the defined pin (echoPin) changes its status from low to high (from 0 to 1)
distance = Speed* duration / 2; //Divide by 2 because we want to have only the “go” time, not the “go and back” time
// and divide by 29,1 because 1 is divided by the sound speed (1/SpeedSound) at cm/us
if ( distance < 20){
digitalWrite (LEDR , HIGH); //If the sensor detects a distances less than 20 cm the red LED turns on
digitalWrite (LEDV , LOW); //and turns off the green LED
else{ // otherwise
digitalWrite (LEDR , LOW); // turn off the red LED
digitalWrite (LEDV , HIGH); //turn on the green LED }
Any help would be greatly appreciated.
