Hi
I use A02YYUW ultrasonic sensor from DFrobot company.
The sample code provided by this company works well for distance measurement.
But it doesn't work well for the project I want.
I'm trying to use the Thread library to work with other sensors. Adding the provided sample code using this sensor doesn't work.
ultdis() ;
please check.
#include <Thread.h>
#include <ThreadController.h>
#include <ModbusMaster.h>
#include <SoftwareSerial.h>
#include <DFRobot_MAX31855.h>
ThreadController control1 = ThreadController();
Thread T_yaw = Thread();
Thread T_dis = Thread();
Thread T_temp = Thread();
Thread T_print = Thread();
SoftwareSerial Yaw(6,7);
ModbusMaster Yaw_sensor;
float Yaw_temp;
float Yaw_x;
float Yaw_y;
float Yaw_z;
SoftwareSerial dis(10,11);
float distance;
unsigned char data_dis[4]={};
DFRobot_MAX31855 max31855;
float temp1;
Yaw.begin(9600);
Yaw_sensor.begin(80,Yaw);
T_yaw.onRun(yawdata); T_yaw.setInterval(100);
T_temp.onRun(tempdata); T_temp.setInterval(100);
T_print.onRun(dataprint); T_print.setInterval(1000);
T_dis.onRun(ultdis); T_dis.setInterval(300);
control1.add(&T_yaw);
control1.add(&T_temp);
control1.add(&T_print);
control1.add(&T_dis);
void loop(){
control1.run();
void yawdata(){
uint8_t result;
uint16_t data[6];
result = Yaw_sensor.readHoldingRegisters(0x3d,4);
if (result == Yaw_sensor.ku8MBSuccess)
Yaw_x = Yaw_sensor.getResponseBuffer(0x00)/ 32768.0*180.0;
Yaw_y = Yaw_sensor.getResponseBuffer(0x01)/ 32768.0*180.0;
Yaw_z = Yaw_sensor.getResponseBuffer(0x02)/ 32768.0*180.0;
Yaw_temp = Yaw_sensor.getResponseBuffer(0x03)/100.0;
void tempdata(){
temp1 = max31855.readCelsius();
void ultdis(){
do
for(int j=0;j<4;j++)
data_dis[j]=dis.read();
}while(dis.read()==0xff);
dis.flush();
if(data_dis[0]==0xff)
int sum_dis;
sum_dis=(data_dis[0]+data_dis[1]+data_dis[2])&0x00FF;
if(sum_dis==data_dis[3])
distance=(data_dis[1]<<8)+data_dis[2];
void dataprint(){
Serial.print(F("x="));
Serial.print(Yaw_x);
Serial.print(F(", y="));
Serial.print(Yaw_y);
Serial.print(F(", z="));
Serial.print(Yaw_z);
Serial.print(F(", yaw_temp="));
Serial.print(Yaw_temp);
Serial.print(F(", temp1="));
Serial.print(temp1);
Serial.print(F(", distance"));
Serial.println(distance/10);
