Ultrasonic sensor HC-SR04 with Python nanpy
Hi everybody,
First of all sorry for my bad english .
So I tried for hours the way to use my HC-SR04 with nanpy, but my script block when I want to read the echo return, and I really don’t know why ! Here my code:
#!/usr/bin/env python
Tire du site:
www.instructables.com/id/Simple-Arduino-and-HC-SR04-Example/?ALLSTEPS
This is the site for the schema.
from nanpy import ArduinoApi
from nanpy import SerialManager
from time import sleep
from time import time
connection = SerialManager()
a = ArduinoApi(connection=connection)
trig = 13
echo = 12
ledrouge = 11
ledbleu = 10
a.pinMode(trig, a.OUTPUT)
a.pinMode(echo, a.INPUT)
a.pinMode(ledrouge, a.OUTPUT)
a.pinMode(ledbleu, a.OUTPUT)
a.digitalWrite(trig, a.LOW)
sleep(0.5)
a.digitalWrite(trig, a.HIGH)
sleep(0.00001)
start = time()
while a.digitalRead(echo) == 0:
start = time()
while a.digitalRead(echo) == 1:
stop = time()
elapsed = stop - start
distance = elapsed * 34000
distance = distance / 2
print “Distance : %.lf” % distance
if distance < 4:
a.digitalWrite(ledrouge, a.HIGH)
a.digitalWrite(ledbleu, a.LOW)
else:
a.digitalWrite(ledrouge, a.LOW)
a.digitalWrite(ledbleu, a.HIGH)
if distance >= 200 or distance <= 0:
print “Out of Range”
else:
print “Distance : %.lf cm” % distance
sleep(0.05)
I think the code stop at “while a.digitalRead(echo) == 0:” I have to do a “Ctrl + C” to stop it.
Here the return of the “Ctrl + C”:
File “./UltraSon.py”, line 31, in
File “/usr/local/lib/python2.7/dist-packages/nanpy-0.9-py2.7.egg/nanpy/arduinoboard.py”, line 55, in wrapper
return fconv(func(self, *args, **kwargs))
File “/usr/local/lib/python2.7/dist-packages/nanpy-0.9-py2.7.egg/nanpy/arduinoboard.py”, line 123, in wrapper
return _call(cls_name, 0, call_pars, connection=connection)
File “/usr/local/lib/python2.7/dist-packages/nanpy-0.9-py2.7.egg/nanpy/arduinoboard.py”, line 28, in _call
_write(id, connection)
File “/usr/local/lib/python2.7/dist-packages/nanpy-0.9-py2.7.egg/nanpy/arduinoboard.py”, line 9, in _write
connection.write(’%s\0’ % str(data))
File “/usr/local/lib/python2.7/dist-packages/nanpy-0.9-py2.7.egg/nanpy/serialmanager.py”, line 87, in write
self._serial.write(value)
File “/usr/lib/python2.7/dist-packages/serial/serialposix.py”, line 460, in write
def write(self, data):
KeyboardInterrupt
I know that a lot of you will tell that I have to use the arduino language but I want to learn with Python :grin:
I thank you for all of you that read my post, and if some of you can think about the problem with me you are REALLY welcome XD
Have a good night,
And keep going !!
Aurélien
What are you running this code on?
You can not run python on an arduino.
Read the sticky post about how to use this forum, it tells you how to post code correctly.
Is ther any code running on the arduino?
Morning Grumpy_Mike,
I am running this code from a raspberry pi with nanpy.
With this python module you can run python on the Arduino, so that's why I try to code with Python :roll_eyes:
Sorry 'bout this, it was very late for me when I posted and it was my first time, I will not do it again :blush:
Yes, the nanpy one, so that you can send the python code directly in the arduino and it can interprete the code immediatly without compiling !
Have a nice day,
No Python dose not run on the Arduino. It is a system for controlling the arduino from python. The arduino runs some sort of Firmetta code that just responds to serial commands from the Pi. The full install instructions are here:-
http://www.raspberrypi.org/forums/viewtopic.php?t=46881&p=546921
This is nothing to do with an Arduino and therefore does not belong on this forum.
Ok no problem,
I see that this forum is helpfull and everyone is welcome !!
So if I want some info on arduino I will go somewhere else !!
Bye !!
Yes it is if they have an Arduino related problem.
However your problem has absolutely nothing to do with the arduino.
You are misunderstanding what that package does, it has nothing to do with the Arduino.
Your error messages are generated by the Raspberry Pi, not the Arduino.
Your problem is with the Raspberry Pi, so ask in that forum.
