Hello,
I was wondering if I could use a Lego ultrasonic sensor with my Arduino. When used with the NXT it tends to be inaccurate but I was wondering if the Arduino would change that.
Here are some links:
http://shop.lego.com/en-US/Ultrasonic-Sensor-9846
Thanks,
Drew Davis
Do you know how I would connect it to the Arduino? The wire that lego uses is just like one that would be used on a landline phone.
Thanks,
Drew Davis
The mindstorm system uses an I2C interface running at 3V3, so you need a bit of hardware, then you need to know how to talk to it. There are lots of examples if you google:-
arduino lego mindstorm
