Hello,
I hope you're doing well. I'm working on a firefighter robot project and have encountered an issue. While the robot successfully senses black lines and moves correctly, enabling the ultrasonic sensor introduces a delay. This delay disrupts the black line sensing and causes the robot's movement to be inaccurate. Below is my code. I appreciate any assistance you can provide. Thank you!
int s1 = 7; //Sensor1 ==> pin7
int s2 = 3; //Sensor2 ==> Pin3
int s3 = 4; //Sensor3 ==> Pin4
int s4 = 5; //Sensor4 ==> Pin5
int s5 = 6; //Sensor5 ==> Pin6
// Motor & L298
//Channel A
int IN1 = 8; // IN1 ==> Pin8
int IN2 = 9; // IN2 ==> Pin9
int ENA = 10; // Enable A ==> Pin10
//Channel B
int IN3 = 12; // IN3 ==> 12
int IN4 = 13; // IN4 ==> 13
int ENB = 11; // Enable B ==> Pin11
// default motors speed
int MotorSpeedA=0;
int MotorSpeedB=0;
//UltraSonic SRF04
int PingPin = 2; // TrigPin ==> Pin2
int EchoPin = A0; // EchoPin ==> A0
unsigned long duration, cm;
void setup(){
//Activate Serial Monitor
// Serial.begin(9900);
//Sensor Setting
pinMode(s1, INPUT);
pinMode(s2, INPUT);
pinMode(s3, INPUT);
pinMode(s4, INPUT);
pinMode(s5, INPUT);
//L298 Setting
//Channel A Motor in Right Side
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(ENA, OUTPUT);
digitalWrite(ENA,LOW);
//Channel B Motor in Left Side
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
pinMode(ENB, OUTPUT);
// UltraSonic
pinMode(PingPin, OUTPUT);
pinMode(EchoPin, INPUT);
//Function for Moving Forward
void MoveForward(){
MotorSpeedA= 110;
MotorSpeedB= 130;
digitalWrite(IN1,LOW);
digitalWrite(IN2,HIGH);
digitalWrite(IN3,LOW);
digitalWrite(IN4,HIGH);
analogWrite(ENA,MotorSpeedA);
analogWrite(ENB,MotorSpeedB);
//function for Moving BackWard
void MoveBackWard(){
MotorSpeedA= 60;
MotorSpeedB= 80;
digitalWrite(IN1,HIGH);
digitalWrite(IN2,LOW);
digitalWrite(IN3,HIGH);
digitalWrite(IN4,LOW);
// Function for stop
void Stop(){
MotorSpeedA= 0;
MotorSpeedB= 0;
// Function for Turning Robot to left
void TurnLeft(){
MotorSpeedA = 60;
MotorSpeedB = 80;
// Function For Turning Robot to Right
void TurnRight(){
MotorSpeedA = 60;
MotorSpeedB = 80;
// read sensors
boolean sens1,sens2,sens3,sens4,sens5; // Variables for Sensor
int SensorDigitalRead(){
sens1 = digitalRead(s1);
sens2 = digitalRead(s2);
sens3 = digitalRead(s3);
sens4 = digitalRead(s4);
sens5 = digitalRead(s5);
return sens1,sens2,sens3,sens4,sens5;
// Print Sensors Value on Screen
void SensorPrint(){
//// Serial.prnt("S1= \n");
//// Serial.print(sens1);
//// Serial.print(" S2= \n");
//// Serial.print(sens2);
//// Serial.print(" S3= \n");
//// Serial.print(sens3);
//// Serial.print(" S4= \n");
//// Serial.print(sens4);
//// Serial.print(" S5= \n");
//// Serial.print(sens5);
Serial.println(cm);
delay(10);
void loop(){
SensorDigitalRead();
if (UltraSonic() == true){
Stop();
else if (sens1 && sens2 && sens3 && sens4 && sens5){
Stop();
else if (sens3 && sens5){
Stop();
// go ahead
else if(sens1 || sens1 && (sens2 || sens3 || sens4 || sens5)){
MoveForward();
else if((!sens1 && (sens2 || sens3 ))){
TurnLeft();
else if((!sens1 && (sens4 || sens5))){
TurnRight();
else if(!sens1 && !sens2 && !sens3 && !sens4 && !sens5){
MoveBackWard();
bool UltraSonic(){
digitalWrite(PingPin,LOW);
delayMicroseconds(2);
digitalWrite(PingPin,HIGH);
delayMicroseconds(5);
digitalWrite(PingPin, LOW);
duration = pulseIn(EchoPin, HIGH); // Measure Time of Fligh in Micro Secondes
cm = MicroStoCm(duration);
if (cm < 10) {
return true;
else{
return false;
//Function For Convert MicroSecondes to Centimeter
unsigned long MicroStoCm(unsigned long MicroS){
return (MicroS/29)/2;
