Ultrasonic Sensor mounted to a Servo Motor (Out of Range Problem)
Hi guys, I would like to ask on how to stabilize my ultrasonic sensor mounted in a servo motor. It is because everytime an “Out of Range” displays in the serial monitor it gives current to the servo motor causing it to sweep. The possibility of sweeping the servo left or right only is when there is an object being detected. BTW, the ultrasonic sensor is mounted above the servo mtor.
Here is my code://
Code: [Select]
#define trigPin 13
#define echoPin 12
#define led 11
#define led2 10
#include <Servo.h>
int pos = 0; // variable to store the servo position
int defPOS = 0;
Servo myservo;
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(led, OUTPUT);
pinMode(led2, OUTPUT);
myservo.attach(9);
myservo.write(0);
long duration, distance;
digitalWrite(trigPin, LOW); // Added this line
delayMicroseconds(2); // Added this line
digitalWrite(trigPin, HIGH);
// delayMicroseconds(1000); - Removed this line
delayMicroseconds(10); // Added this line
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
//0 Left
//1 Center
//2 Right
int buttonState1 = digitalRead(led); //red
int buttonState2 = digitalRead(led2); //green
if( (buttonState1 == 0 && buttonState2 == 1) && (defPOS != 1))
delay(2000);
if(defPOS == 2)
for(pos = 0; pos <= 90; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable ‘pos’
delay(2); // waits 15ms for the servo to reach the position
else if(defPOS == 0)
defPOS = 1;
if (distance < 30) { // This is where the LED On/Off happens
digitalWrite(led,HIGH); // When the Red condition is met, the Green LED should turn off
digitalWrite(led2,LOW);
if(defPOS == 0)
for(pos = 90; pos>=0; pos-=1) // goes from 180 degrees to 0 degrees
defPOS = 2;
else if(defPOS == 2)
defPOS = 1;
else if(defPOS == 1)
for(pos = 0; pos <= 180; pos += 1) // goes from 0 degrees to 180 degrees
defPOS = 0;
//myservo.write(180);
// delay(1000);
//myservo.write(0);
else {
digitalWrite(led,LOW);
digitalWrite(led2,HIGH);
if (distance >= 400 || distance <= 0){
Serial.println(“Out of range”);
else {
Serial.print(distance);
Serial.println(" cm");
