I'm trying to use an Ultrasonic sensor to stop 2 DC motors within a specific distance of an object. I've tested the sensor with an LED which works fine, and the motors run without the sensor. I'm using a Transistor & Diode to Drive the motor. I can see the sensor working in the Serial Monitor, it just doesn't affect the motors.
Here's my code:
const int TRIG_PIN = 11; // Arduino pin connected to Ultrasonic Sensor's TRIG pin
const int ECHO_PIN = 12; // Arduino pin connected to Ultrasonic Sensor's ECHO pin
const int MOTOR_PIN = 3; // Arduino pin connected to Motor
const int DISTANCE_THRESHOLD = 10; // centimeters
float duration_us, distance_cm;
Serial.begin (9600);
pinMode(TRIG_PIN, OUTPUT);
pinMode(ECHO_PIN, INPUT);
pinMode(MOTOR_PIN, OUTPUT);
digitalWrite(TRIG_PIN, HIGH);
delayMicroseconds(10);
digitalWrite(TRIG_PIN, LOW);
duration_us = pulseIn(ECHO_PIN, HIGH);
distance_cm = 0.017 * duration_us;
if(distance_cm > DISTANCE_THRESHOLD)
digitalWrite(LED_PIN, HIGH); // turn on LED
digitalWrite(LED_PIN, LOW); // turn off LED
Serial.print("distance: ");
Serial.print(distance_cm);
Serial.println(" cm");
Thanks for the help
